Best synthetic motor oil for 6.0? - Ford Powerstroke Diesel Forum
post #1 of 51 Old 04-05-2012, 09:47 AM Thread Starter
07DIESEL6L's Avatar
I've been looking at either amsoil or royal purple, which do you guys recommend to be the best oil for our 6.0's?
07DIESEL6L is offline
post #2 of 51 Old 04-05-2012, 09:55 AM
HOTWHEELS34's Avatar
If I had to pick from the two, it would be Amsoil. I prefer Mobile 1.
2005 F350 CC SB ,Turbo-back Silverline 304 ss , RCD EGR delete , Elite VGT-SS turbo , SCT tunes by DJ's , cat delete , Autometer triple gauges , 20" MKW M19 , Toyo 38 x 15.50 x 20 , Icon 4-link 10in. lift , Dual Sway-a-way coilovers and shocks , Pioneer Avic F90BT, OUO Driveline Drop, CCV reroute , FS-2500 oil bypass, Mag-Hytec diff covers , Amp steps
Wanting a Cummins swap.
HOTWHEELS34 is offline
post #3 of 51 Old 04-05-2012, 09:57 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Wow, this will open up a can of worms. Well IN MY OPINION (because at the end of the day that is all any of this is), from everything I have read and the experience I have had with Amsoil, I would say that it is the best oil you can buy. It also very pricey. It has been around forever in the racing world and has done me solid. This isnt to say that there arent any other good oils out there but like I said, IMO Amsoil is the best of them.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
WWW.WPEDIESEL.COM
windrunner408 is offline
post #4 of 51 Old 04-05-2012, 10:16 AM Thread Starter
07DIESEL6L's Avatar
I'm not sold on just Royal Purple or Amsoil, I'm open to other options just trying to get a consensus on what others use on here. I have been using the Motorcraft oil since I bought the truck, but have been reading synthetic will be a lot better in the long run and would like to go that route.
post #5 of 51 Old 04-05-2012, 10:16 AM Thread Starter
07DIESEL6L's Avatar
windrunner, how do you like the IDP FICM? Been talking to Eric about getting one and want to do this in the next month or so
post #6 of 51 Old 04-05-2012, 10:17 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Valvoline Extreme Blue, your 6.0 will thank you.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #7 of 51 Old 04-05-2012, 10:37 AM
BACKYARDIGAN
Quoted: 4 Post(s)
This is what I run in my truck and it doesnt run rough ever. Even in temps below 20F.
AMSOIL Premium API CJ-4 Synthetic 5W-40 Diesel Oil (DEO)
I also like to see how it breaks out against other oils in terms of how its viscosity holds up over time. As you can see Extreme Blue doesnt quite hold up as well. Not trying to bash valvoline oil but just saying what an independent tester found out.
Nate
WWW.WPEDIESEL.COM
post #8 of 51 Old 04-05-2012, 06:12 PM
theswoleguy's Avatar
Quoted: 6 Post(s)
Garage
Mobil ran here just sent off for an oil analysis. See how it goes 5w40 syn... Might try total synthetic.
2005 F250 Fx4, Crew Cab, King Ranch
8" Procomp Lift w/ ext. reservoir shocks, Trac Bars, 22x14 Fuel Mavericks, 38x15.50 Fuel MTs, O-ringed heads w/ valve job, studded, 5" exhaust, Fass Ti w/ RR, XDP Sump, Coolant Filter, Singer 270Amp Alt, BPD 58v FICM, S&B Intake, Powermax, S&B intake Elbow, Snow WMI, ID Tunes, TSD tunes, PHP Ficm Programmer (Atlas 80 majority of the time), Mishimotor Radiator & Intercooler, BPD Water Pump, Gates HD Serp Belt, Flex-a-lite E-Fan Conversion
theswoleguy is offline
post #9 of 51 Old 04-05-2012, 06:23 PM
Turbos = Witchcraft
TooMuch03's Avatar
I run Rotella T6 cuz my truck likes it and it is easy to find. I read a thread a while back someplace where almost all diesel oils were tested, and Redline came out as the best oil to use. For what it costs, it better be the best lol
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #10 of 51 Old 04-05-2012, 07:05 PM
Quoted: 6 Post(s)
Garage
does anyone else get looked at retarded walking into advance and either A)) asking for 15 quarts of Mobil or B) walking up to the counter with 4 gallons of oil?
I go to the same advance most of the time and i swear i get a different person every time and i get the holy hell what do you need that much oil for do you have 5 cars?
My response is i hear there is an oil shortage figure i would stock up, but then again I also tell people "it's a hybrid" when they ask me what the power plug is hanging from the front of the truck's lower grille.
