New External Oil Cooler Kit & Coolant Filter
Check this out. A external oil cooler kit is available from IPR, comes with a coolant filter that filters the coolant before it gets into the oil cooler.
IPR External Oil Cooler Kit for Ford 6.0 Powerstroke |
I would just buy the bpd kit. Eliminate the stock oil cooler all together, plus a spin on oil filter. This kit looks like it still uses the factory oil filter. Plus the added hoses looks like it might be a pita. Just my 2¢
Sent from my smart phone that seems dumb compared to my wifes new phone... |
good link thx.
What's the point in doing this if it's still using a stock oil cooler?
My concern would be, how is the design of the oil filter bypass? What are is the psi of the before/after of the remote cooler housing? How about flow rating before/after? |
This was what I was kind of wondering as well. I mean they do filter the coolant before any of it makes it to the cooler but they even say that there is a possibility that it may still clog. Just seems like a lot work and a lot of space taken up for not much gain. To the OP thanks for the link though.
Reusable oil filter? Seems kinda dumb to do that.
That seems like a tiny coolant filter too. |
The oil filter is not a factory filter, the capacity is larger than OEM which flows about 7-11 GPM The hoses coming off the filter cap are no longer than 36" each. Not that much hose at all considering if you had to run oil hoses from 1 side to the vehicle to the other. Last edited by turbo60; 03-30-2012 at 06:00 AM. |
A reusable stainless coolant filter cuts operation cost down and you can service it anywhere without having spare parts. It's not a new idea, K&N has been doing for years. A larger cartridge stainless steel coolant filter similiar to the size of a bypass coolant filter will be an available option with this kit. |
The gain is to allow easy access in case you have to service your oil cooler. The coolant filter stops the oil coolers from plugging up. The coolant filter is much more effective than a coolant bypass. With a coolant bypass you only filter out a small amount of coolant which is T off a 3/4 heater hose, the internal orifice of bypass filter is only 1/8, this info was obtained from Baldwin Filters. This leaves quite a bit of unfiltered coolant flowing into your OEM oil cooler. Last edited by turbo60; 03-30-2012 at 05:23 AM. |
