6.0 MODS - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-28-2012, 11:19 AM Thread Starter
powerstroke_god's Avatar
6.0 MODS
Hi guys in a month I am pulling my motor to do head studs, egr delete, cat elc coolant, intercooler, radiator, tunes from gearhead, ficm and ecm tunes from PHP, and bpd waterpump. I am thinking of also doing warren diesel 175/30 injectors, airdog 150, hellman sump, and fuel crossover line. What do you guys think? I am looking to get to the 450 to 500 hp range.
2006 Ford F350 Lariat
SCT with WPE tunes
MTW Hybrid turbo
EGR Delete
Coolant Filter
Edge Insight
5" Straight pipe
powerstroke_god is offline
post #2 of 8 Old 03-28-2012, 11:28 AM
Wouldn't you wanna get bigger nozzles on the injectors, like 175/75's?
04 F350 SC LB: Warren Stock+ injectors, Sinister coolant filter, DC Power 185 amp alternator, EDGE Insight CTS w/ EGT, Diamond Eye 5" turbo back straight pipe, S&B intake, MTW Hybrid w billet wheel, Riff Raff boots, Studded, Strokers Unlimited fuel RR system
TruckNorris is offline
post #3 of 8 Old 03-28-2012, 11:30 AM Thread Starter
I dont want to go to big cause I tow 10k every other weekend in the summer
SCT with WPE tunes
MTW Hybrid turbo
EGR Delete
Coolant Filter
Edge Insight
5" Straight pipe
post #4 of 8 Old 03-28-2012, 11:35 AM
You could always get the bigger nozzles, then get two different custom tunes. One specifically for towing that can dial back the flow a bit and another for dd/street use that takes full advantage of them. That's a possibility
post #5 of 8 Old 03-28-2012, 12:04 PM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
I would also do the STC fitting, updated turbo drain tube, and a coolant filter while you are at it.
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #6 of 8 Old 03-28-2012, 01:25 PM Thread Starter
I did the STC fitting when I did the standpipes and dummy plugs and I do have the updated drain tube I will get a coolant filter
SCT with WPE tunes
MTW Hybrid turbo
EGR Delete
Coolant Filter
Edge Insight
5" Straight pipe
post #7 of 8 Old 03-28-2012, 05:43 PM
rdunagan's Avatar
if you ask me id do a rr instead of the crossover line. and do some 50% nozzles i think those would be better suited for you than the 30%. hell if i was thinkin about 30% id just stay stock if it was me. a good tow tune can pull alot of fuel out so that it doesnt get hot
2009 Ford F-350 FX4 4x4, H&S 300HD, MBRP 5" DP back exhaust, S&B intake, sinister egr delete, 4" BDS lift with fox shocks, 20x12 fuel nutz, 37" toyos, Custom painted headlights by me
SOLD: 2006 Ford F-350 4x4 King Ranch,ARP Head Studs and all the works
rdunagan is offline
post #8 of 8 Old 03-28-2012, 06:15 PM Thread Starter
Would a airdog 2 be better then I dont have to do a rr?
SCT with WPE tunes
MTW Hybrid turbo
EGR Delete
Coolant Filter
Edge Insight
5" Straight pipe
