Accufab Elbow - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 22 Old 03-27-2012, 10:23 PM Thread Starter
Accufab Elbow
Anyone know of any suppliers in canada or that ship to canada that sell the Accufab Elbow?
goose5 is offline
post #2 of 22 Old 03-28-2012, 05:34 PM
borsky4's Avatar
I got one through mopac, I think they have a store in the lower mainland bc but I got mine in edmonton, I would sugest the banks one over it though. If u wanna spend the money
borsky4 is offline
post #3 of 22 Old 03-28-2012, 08:18 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Or you can save your money since there is nothing to gain by changing the stock elbow. The elbow is not a restriction and can flow way more than the intake and heads are capable of dealing with.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #4 of 22 Old 03-28-2012, 08:38 PM
borsky4's Avatar
ya hes right I never noticed a diff with the accufab, when i got the banks intercooler it came with the elbow...
borsky4 is offline
post #5 of 22 Old 03-28-2012, 09:49 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
It looks pretty... That's the only reason I'm getting a CFM+.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 22 Old 04-07-2012, 09:58 PM
I added a solid 1 mpg+ when I got the accufab. It was well worth it.
kkonen is offline
post #7 of 22 Old 04-08-2012, 10:03 AM
PGreenSVT's Avatar
I find that really hard to believe when it does nothing to improve air flow. The elbow is not where the restriction occurs. changing parts in front of the restriction has no effect on flow into the cylinder.
Yes I have a CFM+ Largemouth with their metal CAC tube. It is carbon fiber and looks pretty. It will provide a convenient place to hook up a Meth/Water injection setup or pull a mechanical boost feed from. Other than that nothing.
jmeaby likes this.
post #8 of 22 Old 04-08-2012, 11:47 AM
The right angle in the stock piece definitely does not maximize airflow. The poor design is what causes the restriction, not necessarily the diameter.
kkonen is offline
post #9 of 22 Old 04-08-2012, 12:19 PM
Powerstroke Techie
Lilpooh's Avatar
The only benefit of a aftermarket elbow is external ports and "looks pretty".
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 22 Old 04-08-2012, 03:15 PM
PGreenSVT's Avatar
Certainly the oem elbow could be better designed BUT it is capable of flowing more than the intake and heads are capable of using so adding the capability to flow more air there does not = more air into the cylinder. Thus there is no gain in performance or efficiency.
