Evans coolant?? - Ford Powerstroke Diesel Forum
Old 03-25-2012, 07:44 PM
Evans coolant??
I'm thinking about swapping my Gold out for either more Gold cause it's time for a flush and I'm not switching to ELC unless it's Evans. Any thoughts on Evans? Anyone using it and whatcha think about it? I heard it has excellent corrosion protection properties, and because it's a waterless system, you can pop the cap on the degas bottle immediately after driving it at operating temps without the cap blowing in your face. Sounds like a winner to me. The catch is I live in Kodiak, Alaska so where would I purchase it? I have a NAPA here but that's it.
Help me out guys!!!
Old 03-25-2012, 10:47 PM
you have to flush the system first then remove 100% of the water, looks like with shipping it will run around $280 plus shipping, plus flushing
http://www.dieselsite.com/coolant.aspx
2 stroker
Old 03-25-2012, 10:53 PM
BOSS LEVEL
this is a touchy subject on this site for some reason. always has been.
i just dont like what it is really. i mean gold works fine or elc. why waterless. and theres a boil point issue ive heard of. flammable.
Old 03-26-2012, 06:36 AM
2 stroker
I was reading about it and basically you get as much of the water out as you can. You put a 1/6" hole in the degas cap and run the truck for like a week or so. In that time, the remaining water would have burned itself out through steam leaving just the Evans coolant. Not sure if that's true or not.
Wonder why it would be so touchy but that's good to know about the flammable problem. Maybe I need to do more research.....or just flush my system and put the Gold back in with my coolant filter.
Old 03-26-2012, 06:44 AM
Slacker
Feedback Score: 4 reviews
The subject itself isn't touchy, it's just that people get caught up in the moment about defending their position. We had quite a lengthy debate on it a while back and I actually came to switch my position concerning it. Not enough to buy it and run it in my truck, mainly because it is 3x as much as switching to ELC. I'll see if I can find the link for you.
****EDIT: LINK included*****
PS. The flammability problem isn't unique to the Evans coolant, although that was part of the debate as well.
Old 03-26-2012, 06:51 AM
Good enough for me. lol. Thanks again!!
Old 03-26-2012, 10:47 PM
Had to ask, why the Napa fuel filters
2 stroker
Old 03-26-2012, 11:02 PM
Motorcraft Power Stroke Diesel Filter Comparison - YouTube
2 stroker
There's a couple things to consider here:
1. The paper filters in the HFCM and on the engine, in my truck are Motorcraft filters, FD-4616. When it comes to the paper filters, I won't use anything other than Motorcraft.
2. I don't like the "water in fuel" non-sense of my HFCM. Light comes on, drain it. Light comes on, drain it...repeat forever.
So, what I did, was I purchased a NAPA water separator and fuel filter and mounted them on the frame rail, between the fuel tank and the HFCM (the exact same way an AirDog would be setup). That particular NAPA water separator does a hell of better job with the water than the HFCM. In fact, I just had that pump replaced last week (because the pump was corroded) to the tune of $600 total (parts, labor, tax, shipping), not including the $85 tow fee to get it to the dealer.
With that being said, I don't know if you realized the NAPA filters were extras on top of the Motorcraft because if you did, and still think they are bad, that would be like saying the AirDog is a bad setup because that's essentially the exact same thing I have.
Old 03-26-2012, 11:16 PM
All i asked, why the Napa filter, and you told me.
2 stroker
Old 03-26-2012, 11:26 PM
2 stroker
no worries
