Turbo and injector combo advice - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-25-2012, 02:00 PM Thread Starter
Ok guys, I'm stock rite now and am looking for some intel as far as what brands and sizes of turbo and injectors to go with. Looking for some extra tire smoking horses.
Not too crazy expensive if that's possible....
2006 F250 ext cab SB 4X4 74,000
MBRP 4" turbo back straight pipe
SCT Livewire with EGT sensor
Newbe is offline
post #2 of 14 Old 03-25-2012, 02:20 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
It all depends on what you really want your truck to do. I can guarantee you that a set of warren's (either 155s or 175s) injectors with a modded dmax LLY turbo (like Madpowerstroke is doing) will give you a very fun street machine and will smoke your tires all day long.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 14 Old 03-25-2012, 02:23 PM Thread Starter
What is the next size up from stock? What vendors do u guys suggest looking at?
Newbe is offline
post #4 of 14 Old 03-25-2012, 02:29 PM
BACKYARDIGAN
Quoted: 4 Post(s)
In terms of what? Turbo, injectors, or both? Injectors - 155cc with 30% nozzles. Turbo - the most popular is of course the Powermax Garrett gt3788va is the next size up from stock.
Nate
post #5 of 14 Old 03-25-2012, 03:09 PM
Fred@PMM's Avatar
The PowerMax will support up to 175's. We are currently testing some NON-VGT combos for bigger injectors.
Performance Machine & MFG.
Manufacturers of High Quality EGR Delete Kits for 6.0L, 6.4L, & 6.7L Powerstroke Diesels
Toll-free: 877-408-3256
E-mail:
Fred@PMM is offline
post #6 of 14 Old 03-25-2012, 05:14 PM
BACKYARDIGAN
Quoted: 4 Post(s)
I would believe that but that is really the practical limit IMO. It would be nice to see a non-VGT setup with good spooling for some 175s.
Nate
post #7 of 14 Old 03-25-2012, 05:21 PM
back in the saddle
shu873's Avatar
I don't mean to sound like a party pooper but what supporting mods do you have in place, or plan on doing before upgrading injectors and turbo? The least you should have if you plan on injector and turbo upgrades are headstuds and EGR delete. You also need a good monitoring solution that will also read fuel pressure. Depending on injector size you may need to upgrade your fuel system as well. There is more I haven't mentioned.
Have you tuned your truck yet? Get some gauges and a good custom tune and you will be amazed at what your truck can do with stock hard parts...
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #8 of 14 Old 03-26-2012, 05:05 AM Thread Starter
I have a Live Wire with EGT sensor coming. Still waiting to see what all it monitors. Hopefully I will see it today. Other than that just exhaust. I wasnt planning on studs until somthing goes wrong. The "studs or no studs" thread helped. Seeing so many who havent and have had success. Im just a daily driver no racing or anything like that so thot I'd try my luck.
After my programmer gets put on I may be just fine and not want anything else. We will see.
Newbe is offline
post #9 of 14 Old 03-26-2012, 05:14 AM
asian195's Avatar
Quoted: 2 Post(s)
You need to walk before you can run. Have you done exhaust with the tuner? You will be surprised what the tuner will do.
Sent from my smart phone that seems dumb compared to my wifes new phone...
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #10 of 14 Old 03-26-2012, 05:16 AM Thread Starter
No I havent. Ive had the exhaust a week or so and still waiting on the tuner to arrive.
Newbe is offline
