return to stock b4 custom tune? - Ford Powerstroke Diesel Forum
Old 03-23-2012, 02:13 PM
I finally got around to getting some custom tunes and was wondering if I had to return to stock(im running a canned tune from SCT) before I load the custom tune?
Thanks,
Todd
Old 03-23-2012, 02:43 PM
I don't believe so. I have switched between different tunes and never returned my truck back to stock before doing so, and I've never had any trouble..
Old 03-23-2012, 03:59 PM
Feedback Score: 3 reviews
Just be sure to save your stock tune to your PC before hand, just incase something does go wrong.
Old 03-23-2012, 04:47 PM
Send a message via AIM to 0760rmu927
I always return to stock when switching tunes. Just did it tonight actually. It's mostly a just in case thing. It only takes 10 more minutes to peace of mind
Old 03-23-2012, 06:35 PM
Not to hijack the thread, but, I found the free Sparatan tunes for my strategy and tried to load two different tunes on my truck. Neither time the truck would start. I returned it back to stock hoping I didn't damage anything; still nothing. I reloaded with my custom tune and she started right up. So at this point I think my stock file is trashed some how. Remember you get what you pay for...
Old 03-24-2012, 05:44 AM
Thanks guys, I saved my stock file to pc right after I flashed the canned tune. When I did I got a "VIN not correct alpha numeric error". 3 files did transer. flash.lbu, stock.lbu and invalidvin.sul. Anyone have any info on that?
Old 03-24-2012, 08:30 AM
when did this became possible? I wanted to do this years ago but I believe I was told by a tuner that this wasn't an option. Can i do this using liveload? Thanks
Old 03-24-2012, 09:03 AM
Yes, on Liveload. You will see a option for "Get stock file". This will send a copy of your stock file to your PC. Then if you have issues where the SCT device loses/corrupts the stock file, SCT tech support can send you a recovery file that will allow you to load the stock file form your PC to the SCT device.
Old 03-24-2012, 09:05 AM
Forgot to mention, check out the "sticky area", Vivian has a explanation of why.
Old 03-24-2012, 09:12 AM
Glad this is an option finally. Thanks Pooh.
