Need a Batmowheel - Ford Powerstroke Diesel Forum
post #1 of 27 Old 03-20-2012, 06:52 AM Thread Starter
blkdrgn71's Avatar
Need a Batmowheel
Called Bullseye he is out 10-14 days. Any body else have one for sale.07 stock turbo. Thanks, Tim
blkdrgn71 is offline
post #2 of 27 Old 03-20-2012, 07:08 AM
007.3Powerstroke's Avatar
does these really help that much?
2004 6.0 Lifted 8 in 37x14.5x20 inch tires
mods so far:
SCT W/ Tunes
4 in from the turbo back.
Glow shift gauges EGT Boost and Trans temp
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
007.3Powerstroke is offline
post #3 of 27 Old 03-20-2012, 08:17 AM Thread Starter
blkdrgn71's Avatar
Bill said no horse power gain but 100 foot pound of torque gain and lower your egt by 100 F.
post #4 of 27 Old 03-20-2012, 08:22 AM
Quoted: 357 Post(s)
Feedback Score: 5 reviews
Don't you need to machine 05-07 turbos to make the wheel fit.....?
I remember something about it fitting in only 03-04 & Powermax turbos... Just letting you know incase you haven't heard of it
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #5 of 27 Old 03-20-2012, 09:21 AM
well i have a 04 so maybe if i get one it will work. what is the best place to buy them at?
mods so far:
SCT W/ Tunes
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
post #6 of 27 Old 03-20-2012, 11:30 AM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
Is your 04 an early with 10 vanes or a late with 13? Lots of places have them. Maryland Diesel, Xtreme Diesel, possibly Innovative...
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
post #7 of 27 Old 03-20-2012, 12:05 PM
this build date is may 04.
mods so far:
SCT W/ Tunes
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
post #8 of 27 Old 03-20-2012, 12:09 PM
those things arent cheap. and if they dont make a huge difference i dont see spending 400 bucks on one.
mods so far:
SCT W/ Tunes
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
post #9 of 27 Old 03-20-2012, 01:34 PM
Turbos = Witchcraft
TooMuch03's Avatar
I am pretty sure you will need a machined compressor housing then.
2003 F250 6.0
Compounds FTW!!!
post #10 of 27 Old 03-20-2012, 09:00 PM
madpowerstroke's Avatar
I don't think you need to machine anything they are drop in's.Go to XDP,they are great to deal with and have them in stock.I bought a batmowheel off of them for my LLY duramax turbo and it was drop in.As far as the balancing you may hear some one bring up,it's not important.The factory(Garrett) balances the turbine shaft separate from the compressor wheel,the compressor wheel is balanced by thier self so you will have a balance assy. when done.Just remember that a batmowheel for a powermax is not the same as the stocker drop in,and that the threads are reverse on the compreesor wheel.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
