any pointers or tips? - Ford Powerstroke Diesel Forum
Old 03-17-2012, 11:21 AM
IU Hoosier Fan
I got my self a Air Dog II...
Just wondering if you anyone has any pointers or tips when I'm installing the pump...
Old 03-17-2012, 11:37 AM
I just followed the instructions. I didnt run into any issues. Your gonna need a fuel gauge to set the pressure properly. Mine was running 70psi out of the box had to turn it down a little.
Old 03-17-2012, 11:41 AM
IU Hoosier Fan
That is weird cause I was reading the manual and it said that the pressure was preset to 50 psi...
I have a gauge that is why I relized I needed to do something about my stock pump
Old 03-17-2012, 11:44 AM
Yah I read that too, and then set up the system and checked it with my gloshift gauge, and it read 70...So I thought it was just cause it was a gloshift, so I used a buddys snapon fuel pressure gauge to check and it was 69-71psi. So I turned it down a little.
Old 03-17-2012, 11:54 AM
IU Hoosier Fan
nice to know... you notice any gains from the AD2?
Old 03-17-2012, 01:10 PM
IU Hoosier Fan
another question for anyone...
how often to change out the fuel filter and the water separator?
Old 03-17-2012, 01:42 PM
i didn notice any difference in how the truck ran except in the higher rpms on my race tune when my stock HFCM couldn keep pressures up...
I plan on changing mine once a year.. about 12k miles
Old 03-17-2012, 01:50 PM
mine seemed to run smooter and it seems to have a lot more power top end. I was also going to change mine once a year.
Old 03-17-2012, 02:09 PM
IU Hoosier Fan
so you guys changed the water separator also? I have been reading around online and some people said that they never change the water separator...
I did e-mail airdog the same question... I wanna see what they have to say about this..
And performance wise... I'd guess mine would change... since when I go WOT... my fuel psi drops to around 25psi
Old 03-17-2012, 03:46 PM
quick trick to getting the old fuel line off the tank is use a flathead screw driver and go to the side with the driveshaft and pop it off that way. if you do it from the other side you will be there awhile
