Cat back or turbo back? - Ford Powerstroke Diesel Forum
Old 03-11-2012, 05:05 PM
Is there a big sound difference between the cat-back exhausts and turbo back exhausted?
Old 03-11-2012, 05:10 PM
Depends on how you set it up.
What size? Keeping the cat?
Here are some prices...
4" Cat Back.
$213
Diamond Eye K4338A-RP 4" Cat-Back No Muffler Single AL: 2003-2007 Ford 6.0L Powerstroke F250/f350
$244 + muffler
Diamond Eye K4338A 4" Cat-Back Single AL: 2003-2007 Ford 6.0L Powerstroke F250/f350
4" Turbo Back
$229
Diamond Eye K4346A-RP 4" Turbo-Back Off-Road No Muffler Single AL: 2003-2007 Ford 6.0L Powerstroke F250/f350 4X4 Automatic Only
$256 + muffler
http://www.alligatorperformance.com/...ke-p-2458.html
$259 + muffler
Diamond Eye K4346A 4" Turbo-Back Off-Road Single AL: 2003-2007 Ford 6.0L Powerstroke F250/f350 4X4 Automatic Only
Old 03-11-2012, 05:13 PM
Thinking 4" right now because I heard with 5" the truck gets a little goofy or something...
Old 03-11-2012, 06:34 PM
Same question
OK so I am officially a stroker owner as of 3 days ago. Its stock and Im thinking exhaust and cold air intake first. I am also wondering about the pros and cons of cat back or turbo back. Also muffler or straight pipe? Is there a big diff in HP gain or fuel mileage?
Old 03-11-2012, 06:39 PM
leave your stock intake, it has the best filtration! exhaust part other guys need to help... hope they can help you and me!
Old 03-11-2012, 06:43 PM
Hmm ok thanks! Its used but only has 74,000 on it so I just want to take it easy for awhile but thinking the stock exhaust has got to go. Just dont know whats best.
Old 03-11-2012, 07:03 PM
yeah 4" is the way to go the muffler and cat should go bc it will help with the temps and back pressure anything over 4" is a waste of money
Old 03-11-2012, 07:35 PM
also depends on the sound you would like. A cat back will leave the cat in place i believe. A turbo beack system (depending on brand ect.) will delete the cat and you can run a muffler(your choice) if you like. That will get you more grunt from your exhaust
Old 03-11-2012, 07:39 PM
IM good with aggressive sound. Does the exhaust control the amount of smoke it blows or is that controlled more by a tuner?
Old 03-11-2012, 08:09 PM
Not really alittle but def the tuner will do it but with a more aggresive tune will raise your temp so be carsfull watch those temps the smoke is a plus but you dont want to blow the hg's
Sent from my SAMSUNG-SGH-I997 using AutoGuide.com App
