please school me on tunes
ok so i got the sct x3 tuner and i had the looney tune by quick tricks automotive but when i had my head studs done this week i guess they reset it and added a low hp towing tune. it def does not have that kick that it had before it went in the shop. how do i get that back. i am new to diesel trucks and i had another dude do the tune for me. i want my kick back!!!
Reload your looney.
so not to sound ignorant or anything but i just plug up the sct x3 to the computer and the map should show up on the tuner?
Plug the x3 into your obd port and select program>custom>looney tune then press select and it should load into the truck
Yup! Do that ^^^
This all depends if he went to a dealer or a private shop. The dealer may have reflashed his PCM, the private shop may have used his SCT and loaded on one of his tow tunes.
If the private shop used his SCT to reprogram to a tow tune, then he's good to go with just programming in the Looney tune. If the dealer reflashed his truck, then his SCT already has his old stock file in the SCT. So if he were to try and load in the Looney, there is no place in the SCT to store the new stock file. The SCT will only hold one stock tune at a time. |
Just wanna clear up what I already posted.
He has the X-3, so If the dealer did reflashed his PCM, he should be able to reload his old stock tune. Then all should be good to go. |
