Shifting - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-04-2012, 08:38 AM Thread Starter
Shifting
I installed Matt's SRL tune...and I gotta say...my tranny shifts like sh*t !!! I shifts hard, but sometimes feels like it doesnt wanna go into the next gear when it should. Also...if you lay into it, sometimes it acts like it wont go into a high gear (stuck in whatever gear its in until you let off the throttle). Its done this a few time when I jump on it trying to pass people when I was going maybe 40 mph from the stop light. It almost acts like I'm building too much line pressure or something. If I let off the pedal, it will shift. Runs like a molested gorilla from 50 to 100 mph tho. I'm just scratching my head. I'll try and call Matt tomorrow.
I did not mess with any of the adjustable tranny points in the SCT. The only thing I changed was the tire size rotation thing.
tinman565 is offline
post #2 of 9 Old 03-04-2012, 09:04 AM
pizza pig's Avatar
did you let the trans re-learn? If not I highly suggest you do, Matts tunes should shift real smooth under light throttle conditions. When WOT the 5r110 LOVES firm shifts so its supposed to do that. Every tuner uses a fair amount of line pressure under heavy throttle because the trans needs it. Your trans will thank you later.
Dont mess with any of te shift points all that stuff should be left to the tuner
pizza pig is offline
post #3 of 9 Old 03-04-2012, 09:17 AM
2003kingranch's Avatar
His Srl should shift great. Trans learning is important. Give it some time. If it still isn't right contact Matt.
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #4 of 9 Old 03-04-2012, 09:18 AM Thread Starter
How long do you figure (roughly) it will take to re-learn ? I just changed the fluid...so that should be good. It just feels like sometimes the tranny wont shift when you put some decent throttle to it. Almost acts (feels) like if you had a manual tranny, and you pushed the clutch halfway in while accelerating hard....then let the clutch back out when you let off the throttle a little. Does that description make sense ?
I didnt adjust the speedo (with the SCT) for tire size (285/70/17)...could that make any difference ? (like maybe the shifting and speedometer readings somehow affect each other in the tranny program )
'05 KR CC 4x4 DRW
post #5 of 9 Old 03-04-2012, 09:19 AM
I know what your talking about hanging in a gear until you let out. The first time I went wot with it it held 4200 rpm unroll I let out then it shifted. After it learned that's wasn't a problem
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #6 of 9 Old 03-04-2012, 09:22 AM
Go on YouTube and type in Srl powerstroke and watch some vids of the tune. It will give you an idea of how it runs.
Here's a couple of mine.
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #7 of 9 Old 03-04-2012, 09:28 AM Thread Starter
"I know what your talking about hanging in a gear until you let out. The first time I went wot with it it held 4200 rpm unroll I let out then it shifted."
Ok now...."hanging in a gear until you let out" is a perfect description sir.
Secondly....you said it held till 4200....I have my rev limiter set to 3650...could that be part of it ? Maybe I'm on the limiter before I have enough line pressure to shift it ?????
post #8 of 9 Old 03-04-2012, 09:46 AM
i didn't modify my rev limiter. if you modified yours id change it. SRL likes to shift at 4k ish. ive hit 4400 before
like this. mine will hit 4k between the gears
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #9 of 9 Old 03-04-2012, 10:26 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
You need to me sure to set the Rev Per Mile correctly, then drive the truck normal and give it time to relearn. Sometimes it takes less than 20 miles, sometimes less than 50 miles. Really no set mileage when relearn is complete.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
