Smoking cold start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-02-2012, 04:29 AM Thread Starter
Motorboy8769's Avatar
Smoking cold start
When I start my truck after being at work all day it throws a puff of black smoke. Or when I drive away and then let off I may get a small hazy puff is this normal i haven't noticed it before I have stacks and no cat or muffler also stock tuning. Any info would be great.
2008 f-350 CCLB,
Rough country 4.5" radius arm drop lift
doc and Dpf delete
looney street from vivian
Motorboy8769 is offline
post #2 of 6 Old 03-02-2012, 07:02 PM
Have you cleaned the egr valve it could be stuck full of soot, carbon do you run any cetane boost in the fuel. If you need help on pulling it these guys can help little raw but
6.0L power stroke egr repair - YouTube
DTS Articles - 6.0L EGR Valve Cleaning
DTS Articles - EGR Servicing
If needed here is the kit
3C3Z-9P455-AB EGR Valve Gasket Kit
But it could be something different
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 6 Old 03-02-2012, 07:12 PM
Byrd82's Avatar
I had the same problem. But I deleted the egr and cleaned the manifold and I had no more black smoke till I lonney it!
Sent from my Autoguide iPad app
Byrd82 is offline
post #4 of 6 Old 03-03-2012, 07:48 PM Thread Starter
I just bought some Kleen diesel today I put the whole thing in the tank. I know how to clean the egr but the manifold I do not, how would I do that? take it off?? Also where would I order that gasket kit from the ford dealer or someplace else?
2008 f-350 CCLB,
doc and Dpf delete
post #5 of 6 Old 03-03-2012, 07:50 PM Thread Starter
Also don't do it when driving that I have seen
2008 f-350 CCLB,
doc and Dpf delete
post #6 of 6 Old 03-03-2012, 07:57 PM
Byrd82's Avatar
When I deleted the EGR I did take off the manifold. Then took it to the u do car wash then cleaned it up there. You can give tousley ford a call and get the gaskets you will need.
Byrd82 is offline
