egr and tuners ??????? - Ford Powerstroke Diesel Forum
Old 09-18-2007, 06:26 PM
Send a message via Yahoo to phillipsblues
I'm having problems with my egr. it blew out last month and i had to have it replaced and a new turbo. it is in the shop and it is getting another egr. i have a banks six gun and was wondering if it is the cause of my egr problems. i few of my friends have the edge with attitude and they are twice as hard on there truck than i am and they haven't had any problems. one of them still has the factory exhaust and intake.
i like the power and the way my truck preforms with the chip i don't want to have to stay stock to stay out of the shop. will the sct take care of my problem?
it doesn't make sense to me the banks is supposed to supper safe compared to most tuner's.
Old 09-19-2007, 08:40 AM
bump it up
Old 09-20-2007, 09:46 AM
i got my truck back today and they said that they had to change the oil cooler. that was the reason my egr went out bothtimes. does that make seens to yall?
Old 09-20-2007, 09:57 AM
Send a message via AIM to 6.0Sean
An SCT with custom tunes, keeps the EGR valve closed, this will keep the EGR from getting gummed up. I personally dont know why your truck is having problems compared to your friends, hopefully someone else will know more.
Old 09-20-2007, 10:13 AM
Dump the banks and get an sct, you can also do an egr delete pipe.
Old 09-20-2007, 10:51 AM
Slacker
Feedback Score: 4 reviews
EGR cooler? yes. EGR? no.
Old 09-20-2007, 11:05 AM
they said that they changed the oil cooler and the egr. i had to take it to the shop last month and the changed the egr. they sid that the oil cooler was the cause of the egr problems
Old 09-20-2007, 02:30 PM
Send a message via AIM to gtdan01
From what I gather the oil cooler starts to get plugged so then the EGR cooler gets less flow and won't cool as well and can crack. Oil cooler is before the cooling flow to the EGR cooler, I think I am having the same problem, I will see this weekend though.
Old 09-20-2007, 09:06 PM
I doubt your banks is the problem. IF I had banks I don't think it would be the cause. EGR valves have issues on stock trucks. It's nice to have the tuned xcal2 to turn it off.
Old 09-20-2007, 09:38 PM
it is a common problem even in stock vehicles, but banks/edge are both more harmful to your vehicle than the SCT is, because they increase cylinder pressures so much more.
once they replace your stuff, get rid of the banks, get the sct. and the sct can also be programmed to eliminate the egr operation. and get an egr delete kit which replaces one of ur up-pipes and has a block off for the egr valve. you could then remove the egr cooler if you wanted to, and reroute your coolant lines.
