What to do? - Ford Powerstroke Diesel Forum
Old 02-29-2012, 05:08 PM
Fuel pressure gauge... what to do?
I want to monitor fuel pressure in my 6.0.
I have a triple A-pilar with Isspro EV1 gauges (boost, trans temp and EGT)
Also have Edge CTS.
So what have you done or what would you do to monitor fuel pressure?
Old 02-29-2012, 05:12 PM
You need to connect a pressure sending unit and gauge to the test port on your engine mounted fuel filter or get one of the billet fuel filter caps that has a tapped hole in it. No other way.
Old 02-29-2012, 05:17 PM
Are you asking if you should monitor it with the cts or another gauge
Old 02-29-2012, 06:34 PM
Yeah... CTS or another gauge? Seems like a lot of $$$ to get the CTS to monitor FP.
Old 02-29-2012, 07:30 PM
This is the way i went i have the older edge but not for long that way i can watch 9 things at one time some guys go with the Glow gauge but i just like the Autometer or Isspro i have the Isspro in my 97
This is what i got for the fuel pressure gauge, it goes into the test port, this is a cool set up gets the sender away from the heat and viberation of the motor.
Page 30: Fuel Supply System
6.0L Fuel Pressure Adapter
Column Pod
1 Gauge Column Pod (AT)
Autometer Fuel Pressure gauge---Bottom Left (This matches my Dash gauges)
Phantom II Gauges
2 stroker
