Need A Fuel Pressure Gauge - Ford Powerstroke Diesel Forum
Old 02-24-2012, 03:50 AM
Im in need of a fuel pressure gauge. want to do a steering column mount, on the right side. and need a fuel pressure gauge, and whatever else i need. wheres the best place to get what i need. i would like to give a site sponsor business. and if anyone has some pics of theirs that would be great
Old 02-24-2012, 01:11 PM
Check out DieselManor.com. They got what you need and they're on the .org.
Old 02-24-2012, 08:25 PM
This is what i got for the fuel pressure gauge, it goes into the test port, this is a cool set up gets the sender away from the heat and viberation of the motor.
Page 30: Fuel Supply System
6.0L Fuel Pressure Adapter
Column Pod
1 Gauge Column Pod (AT)
Autometer Fuel Pressure gauge---Bottom Left (This matches my Dash gauges)
Phantom II Gauges
2 stroker
Old 02-26-2012, 05:28 PM
so i got the column pod figured out. fuel pressure adapter is a must for sure. what kind of gauge should i go with? how junk are glowshift gauges? i can get a 0-100 psi for $60
Old 02-26-2012, 05:37 PM
I'd get an electric sensor that goes right on the fuel bowl or where ever you 6.0 guys tap into it. one. Less chance of leaks.
Auto Meter
Old 02-26-2012, 05:58 PM
I've got the 0-100 tinted 7 color series GlowShift and it's great. Comes with the sending unit. I also used the adapter from ITP. The whole setup is awesome. I've run GlowShift gauges in several vehicles. There are no problems that all the other gauges manufacturers don't see as well. My GlowShift has been working great for well over a year now, as a matter of fact I'm about to get the GlowShift 0-60psi boost gauge to match.
Old 02-26-2012, 06:00 PM
well just ordered a column pod and fuel adapter from strictly. also ordered a 0-100 glow shift gauge. if the gauge sucks ill buy a autometer one.
i figured if i have low fp then ill be ordering a airdog 2. so there's another $150 towards it.
Old 02-26-2012, 06:02 PM
Column Pod
Phantom II Gauges
2 stroker
2stroker, I noticed that column mount says it's for 99-04 trucks. Is that mount what you have? And if so did it work as it came or did you have to modify? I would love to have a column mount for my boost gauge.
Old 02-26-2012, 06:06 PM
good to hear. i cant wait to get all my parts should have them before the end of the week.
Old 02-27-2012, 09:38 AM
Yes that is the one i have but i got mine from FCDP but it is the same one my paper work said Ford Super Duty 99-01 Steer Clm Pod (Auto) 2 1/16"
2 stroker
