One for One or full cab off?
Alright guys I need some help deciding what i should do, i got a 06 f-360 6.0l with 84,000 on her and i want ot do head studs, i got a quote from one shop for $1700 to do one for one head stud replacement with a egr delete. Then i got another quote for 4800.00 to do full cab off with egr delete. what should i do??
Take heads off machine them replaces both gaskets w/ OEM head gaskets and install ARP head studs.
do this work with CAB ON!!! This requires a new quote, or do it yourself |
id do it with the cab off! much easier to do and less strain on the ol back!! thats the only way i do them. im not downing the guys that do it cab on at all i just dont have the balls to do it with the cab on because of how stressful it can be. to answer the question though do it right and pull the heads off
I don't see how shops say they can do a one for one change out when there is a head bolt that must come out with the head. The stud is slid into that head when it goes back on. Maybe they are pounding on the firewall to get the clearance. Either way, it seems pretty extreme measure to stud it if you don't have an existing head gasket issue. If it's not broke, why fix it?
I have 93K on mine and I'm not studding it until it pushes a gasket. |
why not add some torque to the stock head studs, say 3-5 more foot pounds? since thats what lets the head lift off the block to cause the head gasket problem...
just a thought |
Before tuning, HAVE GAUGES, after tuning, DON'T hit the loud pedal before it is at operating temperature. |
I guess I am meaning like that "stacking chips" crap that some people used to do, and running tunes written for studs if you aren't studded, like SRL+ or SRL Estreme, etc. I assume you are monitoring your engine and maintain it well since it is holding up.
Stacked programmers/tuners! That sounded stupid when it was the "in" thing to do. That is EXACTLY why I won't use my Edge for JUST a monitor like some guys do when their Edge power adder poops. It seems too easy for the Edge and SCT to gang up on my truck and beat it down! ![]() The Inisght is MADE to be just a monitor, pls don't confuse that with what I am saying here. |
