river city diesel - Ford Powerstroke Diesel Forum
post #1 of 43 Old 02-22-2012, 05:42 PM Thread Starter
river city diesel
Ok so i got river city diesel injectors, had them put in professionally! ever since my truck has ran like CRAP!!!!! first it was over fueling so they sent me new one. it has had this weird lope idle-ish thing happening. it even lopes on deceleration! i spent 3 hours at a very reputable shop today with the computer hooked up doing a power balance tests, ficm test, tested ipc and ipr, tested fuel pressure, everything is good except on the power balance test it freaks out on decaleration. the truck cuts out when warm at idle! Please correct me if i'm wrong but it sound like bad injectors to me!?!?!?!?!?!?!? BEWARE OF RIVER CITY DIESEL!!!!!!!!!! I will post a vid of how it runs after river city sees it!
tbaer is offline
post #2 of 43 Old 02-22-2012, 05:46 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
What size injectors?? Have you tried updating your tune??
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 43 Old 02-22-2012, 05:51 PM Thread Starter
i have 3 tunes from rcd and 3 tunes from vivian and 3 sct tunes and they all run the exact same besides the rcd lope tune which runs abosolutly like crap!
tbaer is offline
post #4 of 43 Old 02-22-2012, 05:52 PM Thread Starter
injectors are 155cc
tbaer is offline
post #5 of 43 Old 02-22-2012, 05:56 PM Thread Starter
the truck is a late 04 has 83k on it, powermaxx, egr delete, new cam and crank sensors, s&b intake, zoodad, air dog 2
tbaer is offline
post #6 of 43 Old 02-22-2012, 06:54 PM
hazard's Avatar
this may be a little off subject but it somewhat ties it with this odd situation. so here is the situation, i work for cummins, we have an older school bus come in for missing when putting into gear and at random times, well we diagnose for a failed vp44, so we put a new one in and same thing occurs... try all sorts of things, we ran this engine with the entire oem harness unhooked and still suffered from same symptoms, we put a new engine harness on and same issue... at this point there is alot of heads in the game on this issue, and somehow i get brought into the mix, and we decide to pull the tranny back to make sure the torque converter isnt messing up and causing this issue and come up with nothing, we decide to have the tranny dynoed to be sure we have no issues in the tranny we arent seeing, so while the tranny is out to be dynoed i am at my wits with this bus and i have made a vow to fix this thing, so i convinced one of the suits in the office to let me put a set of factory injectors in it ( i knew the bus barn put a set of sticks in it that were 245 horse injectors, which is a common practice for vp44 isb busses to get some extra power..stock was 195 horse.) they bought these sticks from a local injection shop which said that the issue we was having the oversized injectors wouldnt cause... well i went against that and put stocks back in this bus today and fired it up and the issue is gone... now i dont know if they just bought a poor set of built injectors or what but something wasnt right and its obvious it was the injectors... at this point i am very leary on injectors being built by a non reputable builder... not saying river city diesel isnt a good dealer but it may be something to not be ruled out. i realize my situation isnt with a 6.0 but with a cummins 5.9 but in a sense its somewhat of the same issue.
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #7 of 43 Old 02-22-2012, 07:30 PM Thread Starter
EVERYBODY i talk to with river city injectors has the exact same story! i dont care if it costs me 5 grand i'm going to make sure river city diesel never sells another junk injector again! it is causing overfueling in my truck and that creates cylinder wash and ruins rings of i'm not mistaken.
tbaer is offline
post #8 of 43 Old 02-22-2012, 07:31 PM Thread Starter
what compant is very good with larger injectors? i am in the market for new ones!
tbaer is offline
post #9 of 43 Old 02-22-2012, 07:36 PM
f250ghost's Avatar
HAHA...I'm sure a few guys around here could attest to my fiasco I had with them...
-Ben
2011 F250 FX4
6.7 PowerStroke
f250ghost is offline
post #10 of 43 Old 02-22-2012, 08:35 PM
Beef52751's Avatar
Ryan Casserly at Full Force Diesel, i have no personal expeirence with him but have heard nothing but great reviews
2006 CCSB F-250 King Ranch FX4 6.0
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
Boost, Pyro, and Fuel Pressure Gauges
Beef52751 is offline
