edge insight installed - Ford Powerstroke Diesel Forum
Old 02-22-2012, 03:46 PM
i have an 05 ex with 50,000 and just installed the insight monitor. Ficm is showing 48.5 just as the key is turned to start 48.9 at the moment the truck starts. While driving it averages 48.9. And the delts between coolant and oil is 3 to 4 degrees.
So i guess i am okay for now?
Old 02-22-2012, 06:00 PM
Throw a coolant filter on there, easy and well worth it!
Old 02-22-2012, 07:45 PM
Now get a coolant filter on run for 5-7000 miles then do a coolant flush install a CAT EC-1 Rated ELC coolant then your cooling system will be good.
You can order here
Performance Machine & MFG. 6.0L Powerstroke Diesel Coolant Filtration System
or here this is a good deal
Ford Superduty Powerstroke 2003-2007 6.0L Coolant Filter Kit
Then you will need to get a fuel pressure gauge because under 45lbs at WOT will kill injectors but you have a good start on things.
2 stroker
Old 02-23-2012, 01:49 AM
thanks
thanks guys
