Stuck in Afghanistan... ordered some new goodies
Hey everybody. I haven't been on in a while, and I really really really do miss it. I am currently in Afghanistan and will be here for a while. Hope all is well with everybody.
I just ordered some new goodies for the truck and I am anxious to get it all on before I get home. Just purchased some ARP head studs, Garret Powermax, Casserly 155's, and AirDog 2. Hopefully I will see some good stuff out of everything. My next step is to get my SCT re-flashed by Eric and IDP. Anybody have a similar setup and have any mileage numbers or input on how everything runs? Also do any of yall have any suggestions on a transmission rebuild/new trans and torque converter. I was suggested Brian's Truck Stop. Keep in mind I don't want to break the bank, however I want something strong and reliable and somewhat reasonable in price. If the price will be high regardless of what company, then who should I look into? Thanks in advance. |
Are you looking into transmissions because of your predicted HP level, or is yours bad? Reason I ask, is because your trans should hold up fine to the new power level. ASSuming your current trans is good, save your money.
Keep your head down, and thank you for your service. |
05diesel60, thank you for your service.
As svilla said at that hp level your trans will be ok unless its on its way already. With those mods I would guess you at 480 to the tires. You might want to consider the ficm tuning and some 6.4 banjo bolts in addition to your list. Both are well worth it in my opinion. |
Hey 05Diesel60 I have the perfect guy for you to do this. I have a buddy who is a certified diesel mechanic and works at a ford dealer and runs a shop above his house. He does the best work around and does a clean and miticulous job. He has replaced my HPOP, Injectors turbo and all before so he has done all of what you are wanting to do, I am in Western North Carolina and he is about 15 min from me. I would be willing to pick your truck up and get the work done for you and then take your truck back home or whatever. He does great work for a VERY reasonable price, he replaced 4 injectors for me for a VERY VERY cheap price and a man of your stature would be just as well treated as he treats all customers. Just let me know.
Stay safe brother! Keep your head down and remember, "Its better to be tried by 12 than carried by 6!"
Thanks everybody. It's not so bad out here... just a little cold, wet and dusty when the rain kicks down. As far as my trans is concerned it seems to be alright so far. Truck has 138k last time I checked, however the wife likes the truck too so that number could be slightly fudged now
. If a new trans isn't necessary, then how about a torque converter? I was just doing the trans and TC to have it new and fresh, but if I can stay away from it for now then I may do so... or just spend money to satisfy my sick addiction ![]() What is the reason for going with the new banjo bolts? Thanks for all the help guys, much obliged. |
Banjo bolts basically open up the bolt for more fuel delivery. The 6.0 bolts have check valves in them and the 6.4 bolts have 4 fuel holes instead of 2 and no check valves (they are hollow bolts)
Thanks CumminsKiller. Just read some posts as well. Thanks for the info guys.
Depending on how close you are to Knoxville, we have all Factory Ford trained techs. We would even be willing to extend you a military discount for your labor.
