Labor for egr delete
My truck is at the dealership for headgaskets. The cab is off and I just dropped the heads off at the machine shop. I have the dealership talked into installing apr studs and an egr delete upon reassembly. How much additional labor will that be for installing the delete as opposed reinstalling the egr cooler? I am trying to get a fix for what I should be charged for the delete.
Since they are already in there, it would almost be less work to install the delete than it would to put the old cooler back on.
What about your oil cooler? Are you replacing that while they are at it? |
They said the oil cooler is fine but I am going to have them replace it anyway. I cant do the bulletproof one right now$$$$$$, so i am going with oem and just stay on top of the flushes to keep everything nice and clean. I think I will have them put on a coolant filter as well....any ideas on labor on that one??
Labor for what? Putting on a coolant filter?
Might take you an hour/45 minutes in your driveway with a screwdriver and a socket set....with beer and cig breaks. |
they shouldnt charge you to do the egr delete since the heads and stuff are off. if they do tell them that it was part of reassembly anyways and take it off. 9 outta 10 shops wont charge labor to do it if they are doing the heads at the same time. but say you just wanted an egr delete done the book time on it is close to 8 hours i think but most of the time can be done in 4-6. when they start the reassembly though all they would have to do is remove the egr cooler which at that point would be 2 bolts and then put the delete on which is another 2 bolts and your done. if i were you id fight for them not to charge you because if they do thats BS! and the oem oil cooler will be perfect! to me the BDP is nice but overpriced for me.
Ford TSB detailing the maintenance requirements for using the Ford Gold coolant in Powerstroke Diesel engines... CLICK HERE |
Thanks for all the info!
Sent from my ADR6300 using AutoGuide.com App |
since you guys are discussing the egr delete I have a quick question. I just bought a 04 6.0 crew cab 4x4 king ranch with 83k (mint cherry!) I am wondering what are all of the pros and cons to this. And just some insight my father has been a diesel tech for about 30 something years for the same company so all mods and stuff we will be doing ourselves. Beside we have plenty of friends who also are diesel techs that own them and have already done this process I just wanted to hear yall fellas opinion if I should do it really really soon or the apr studs first and all that great stuff...? Thanks in advance for the insight and help.
