18mm or 20mm head gasket?? - Ford Powerstroke Diesel Forum
Old 02-15-2012, 04:04 AM
I got an 06 6.0, I have read that engines built 03-05 have 18mm and engines built 06-07 have 20mm. Where can I find a build date of the engine, or is it just a best guess thing?
With my truck being an 06 i just thought that the engine might of been build in 05 and sat around or something. I just want to make sure I buy the right ones the first time.
Old 02-15-2012, 04:39 AM
Check the build date in your door, if it is Pre-January 06 Build its for sure 18mm. Anywhere after that you would need an oasis ran to find exact build date. Also, if the truck has had heads replaced under warranty it can still be a 20mm and require the use of a step dowel.
Old 02-15-2012, 04:55 AM
if your truck is pre jan 06 do you have to run 18's or can you run 20's
Old 02-15-2012, 04:59 AM
If your heads are 18mm you will have to use 18mm gaskets, if your heads are 20mm you have to use 20mm gaskets.
Old 02-15-2012, 05:24 AM
ok thanks guys for the quick response!
Old 02-15-2012, 05:52 AM
Almostdunfukinwidit
Or if you can still read the sticker on the valve cover the engine build date is noted on it.
