Head Gaskets
I have been looking around at a bunch of different posts about head gaskets for the 2003 6.0l and i was just wondering if i should just stick with OEM gaskets when i stud and egr delete, or should i go with a aftermarket product??
Can't go wrong with the OEM's some think the Black Onyx are better, but in my opinion either is fine as long as you follow proper procedures. The Black Onyx seem to be more finicky to a better block/head prep. Either way the heads need to be milled at a machine shop to insure that they are flat. Following the Ford procedure for warpage is just too loose of tolerances.
^very well said.
I think both gaskets are alike in the fact they both work best with heads that are perfectly flat and I think lots of people arent checking the heads when doing studs then having issues down the road with pressure and automatically blame the gasket wether it be the black or oem gaskets, what we have found is if there is pressure is in the system after studs and gaskets are done you have a deeper problem with the bottom end. |
ya. I’m getting ready to do head gaskets as well. I’ve been back and fourth on which head gaskets to go with? $150 for black ox. $190 a side oem= $380. That’s a big difference to me. And if I have a deeper problem. Then it’s a real big difference. I’ll need that money to fix that.
Stick with OEM. Read these 2 threads if you think you can make the black onyx ones work.....
Cab off headgaskets, studs, Oil cooler, STC fitting, and injector swap-PICTURES 10,000 miles on my Black Onyx heagaskets! So far, so good. Make sure you read the last page on the second post. This guy did all the prep work and still had issues. I will only use OEM gaskets. |
What gaskets did you use and were the heads checked for flatness? Was the work done by a dealer? They are notorious for torquing the studs to Ford Specs and not the ARP Specs, no gasket will last if they have used the incorrect specs. |
Fred@PMM- oem bolts or arp? if ARP ill take 3 sets lol no joke
OEM Bolts, thats the same kit you buy from the dealer. Includes Bolts, Dowels, Head Gasket, & Stand Pipe. Our kit with OEM Gaskets and ARP Studs are $749.95, all our FORD OEM Parts offerings can be found here: Ford 6.0L Powerstroke 03-07 - Ford OEM Parts
I will be doing ARP studs, I've only heard good things about them. I havent had any failures with my truck yet, im just planning a head, and taking care of the problem before it does decide to blow. what would be the deeper problem in the bottom end if there was one?? I'm still new to the scene of performance diesel and trying to learn everything i can about it.
