Bypass Coolant filter leak
Dieselsite model purchased this past summer. So the T fitting on the heater hose leaks when it's cold at night. I've re-tightened it, moved the hose clamps slightly, but still a puddle in the driveway in the morning. Any suggestions?
Since it doesn't say otherwise in your signature, are you sure it's the by-pass and not the EGR cooler? My mystery winter puddle was the EGR cooler leaking from that crappy OEM hose clamp. A delete kit fixed it.
I can see and feel the coolant right at the T fitting. I'll have to look at that egr hose too when it's light out
If it is the T fitting then you could always considering replacing the hoses with the hose kit from PMM.
2 stroker |
Sorry 'bout that. So there's an updated fitting from dieselsite? I looked but didn't see the part listed for sale.
-Matt H Sent from my Autoguide iPhone app |
Is it the fitting it self, or is it the connections to the hose? Tephlon tape it and see if that helps.
It's the hose and fitting connection. Will try a bigger hose clamp over the barb and snug it up. Hope that works. If not then a new fitting is in order or maybe adding some Teflon tape as suggested
Anyone remember the dimensions for the reducer t for the heater hose? Its 3/4 x 3/4 x 3/8 right?
