Exhaust questions - Ford Powerstroke Diesel Forum
Old 02-13-2012, 02:19 PM
Exhaust questions
I have a 2005 F350 stock exhaust. I have another complete turbo back exhaust at my house for some reason, not sure why. I was looking at the MBRP 4 inch turbo back with out cat and muffler (straight pipe). My question is what is the difference between that and me taking out the stock cat and muffler out of my spare exhaust and welding in pipe to make it, in essence, a straight pipe?
as for mods It has a filter, and an Edge juice with attitude platinum. I drive it daily to work and from work and I tow 3-4 times a year so I am not hard my truck in any way. I know the edge isnt the best but I believe for what I am using it for its ok? I am sure 95% of the people on this site use their truck for what it was built for, sadly I am not one of those people... yet
Thanks guys.
Old 02-13-2012, 02:37 PM
You may not want weld. In CA, we get 'smoke' tests every other year. Welded sections would make it hard to put back the 'stuff' necessary to pass the visual part of the test.
Something to consider.
Old 02-13-2012, 02:42 PM
I have 2 stock exhausts. 1 would stay stock and the other would be cut and welded. I just dont know if it is worth it to do that to save a few bucks. all one piece seems like a better idea so that there are no leaks, or problems that can happen. IDK.
Old 02-13-2012, 02:53 PM
id just clamp it but dont use the U bolt clamps and it will make it 10 times easier to do.
Old 02-13-2012, 02:56 PM
so you are saying dont buy the exhaust and just cut and clamp the spare stock exhaust that I already have?
Old 02-13-2012, 03:15 PM
Thanks guys.
The biggest difference is the volume of air that the 4" system moves versus simply deleting your cat and muffler. Mine had a deleted cat and aftermarket muffler when I bought it. I purchased a Dynomax cat back only and there was a definite difference going from the 3.5 to 4" tube. I'm running a 3.5 down tube and 4" straight pipe now.
Old 02-13-2012, 03:16 PM
That is what I was thinking. I think I will go with the new 4' MBRP straight pipe
