Just bought my first diesel - Ford Powerstroke Diesel Forum
post #1 of 16 Old 02-13-2012, 01:40 PM Thread Starter
I just bought my first diesel. 2006 F-250. I bought the EDGE REVOLUTION programmer for it and was wondering, I do not have head studs but only plan on using the economy mode or tow mode. Am I safe or is head studs still required even though im not gonna use race mode?
fire_ford is offline
post #2 of 16 Old 02-13-2012, 01:47 PM
Quoted: 365 Post(s)
Feedback Score: 5 reviews
Congratulations,
You have baught a wonderful gauge setup. Did you get the CS or the CTS?
DO NOT use it as a tuner because the "shift on the fly" tuners add HP but do not tune the tranny to receive that much power, leaving the owner with an unhappy/broken tranny soon after.
Buy a SCT tuner with custom tunes, your truck will love it and so will you!
But, like I said, the first thing a person needs to do on a 6.0 is GAUGES, which you just bought the most popular/universal piece of equipment to use!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #3 of 16 Old 02-13-2012, 01:48 PM
quillin_james's Avatar
as many people will tell you on this site. your motor can blow at stock. so i guess time will tell. if it does, atleast you can throw 5+k into it and fix it right.
quillin_james is offline
post #4 of 16 Old 02-13-2012, 02:05 PM
Edge has a great set of gauges but there tunes may kill your trans. Get a coolant filter on ASAP to remove the casting sand that helps plug the oil cooler then after 5-7000 miles do a coolant flush need to know deltas the health of your motor.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #5 of 16 Old 02-13-2012, 02:29 PM Thread Starter
I might sound stupid but by guages do you mean just use it to monitor my system and not use the economy or tow mode? Sorry but new to diesels and don't want to screw up lol.
post #6 of 16 Old 02-13-2012, 02:39 PM
Quoted: 365 Post(s)
Yes that is exactly what we mean.
dont use the tuner on any setting other then stock and use it as gauges for oil temp coolant temp, Boost PSI, Trans temp, FICM Volt, Fuel Pressure, and EGT temp.
For a tuner, research SCT x3 w/ custom tunes
Also, start by reading this thread ALOT of your questions will be answered!
Things to consider about owning a 6.0L
Studded and Deleted
post #7 of 16 Old 02-13-2012, 03:05 PM
Fox Hunt's Avatar
Quoted: 30 Post(s)
If you can I would say send the Revolution back and just get a CTS or CS. Then take the money you get back and put it towards a SCT.
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #8 of 16 Old 02-13-2012, 03:19 PM
Quoted: 365 Post(s)
There is no such thing as a "Revolution"...
He probably meant "Evolution" which only has 2 types.
CS= smaller version w/buttons
CTS= 4" touch screen
OP: Which one did you get?
Studded and Deleted
post #9 of 16 Old 02-13-2012, 04:53 PM Thread Starter
Yeah sorry its the Edge Evolution. I have been doing some reading on it and the version I bought says it adds transmission line pressure. Does that not mean its tuning the trans as well? Ya'll have to forgive me all this programming business is completely new to me. I do appreciate all the feed back so thanks everybody.
post #10 of 16 Old 02-13-2012, 06:49 PM
Turbos = Witchcraft
TooMuch03's Avatar
Feedback Score: 3 reviews
Did you get the CS or the CTS? The good thing about the Edge is that you can add a pyrometer and fuel pressure gauge to it, which is something you should monitor. I would say that you should be safe running the tow or economy tune without damaging your tranny. The Edge Evolution just boosts line pressures which will make the shifts firmer and quicker, but this is not true transmission tuning. However, if you are interested in custom tuning, which I agree is the best thing for the engine and transmission, you could send it to PHP and they will be able to tunr it into a Gryphon with custom tunes made specifically for your truck. Here is the link: Gryphon
2003 F250 6.0
Originally Posted by Tuscany View Post
Compounds FTW!!!
TooMuch03 is offline
