READY TO CHANGE OIL FOR THE FIRST TIME SINCE INSTALLING BULLETPROOF EXTERNAL OIL COOLER AND GIANT FILTER THEY SEND--
ANYONE KNOW THE PROCEEDURE - WILL I HAVE TO PRIME THE LINES AGAIN? HOW MANY QUARTS?? ANY ADVICE WOULD BE MUCH APPRECIATED ALSO- INSTALLED EDGE CTS- ALL I CAN SAY IS WOW- IMPRESSIVE |
Change it like normal.
And all caps seems like you're yelling at everyone.. lol |
sorry
how many quarts will it take do you know?? and im using T-6 synthetic- is this wise with 108K miles?? |
lol. All good. My dad types in all caps. Heck, he even write in all caps.
![]() And you should add 15 to a stock 6.0l. So you should need 16 with the bypass (4 gallons of oil) then you should have spot on amount. Synthetic in a 6.0 is one of the best things to do for it. Rotella is good, I use Valvoline. Use synthetic as long as you can afford it
If you need to buy some oil for the change check out THIS THREAD.
I could be way off base here, but I have a friend who installed the Bullet Proof external cooler about a year ago. I am pretty certain he said this pushed the oil capacity to 20 quarts. I don't know much about the system, but what he said makes sense to me. You now have to fill that external cooler & gigantic filter with oil.
Hopefully somebody who has the system will chime in and know the answer. If not, I would find a way to measure what comes out when you drain it so you will know how much to put back in. Then check the oil religiously for a little while to make sure your level is correct. |
I'm willing to bet that BPD would know the answer...
Not all the old oil is going to drain out of the cooler. So no, you don't have to compensate for that unless you completely purge the system.
One extra quart is for the filter. |
Got it done- the answer to this thread is--
18 quarts exactly Filled the big filter- cooler and system to the top of the stick!! Bulletproof claimed 21 That must be for a dry motor!! 18 is perfect! Let drain for 30 minutes Plug the pan Untwist the massive filter Not a drop spills!!!! Fill filter Pour in the motor the remaining ammount to the 18 quart capacity Start engine Shut off Wait 5 min Check oil level Will be right at the top of the cross marks on the dipstick |
Wham, bam, steal the van.
Good job |
