Regulated Fuel Return? - Ford Powerstroke Diesel Forum
post #1 of 36 Old 02-09-2012, 05:48 AM Thread Starter
ptsk06tank's Avatar
I have got a question on RR.
OK if a Aeromotive A1000 puts out a constant pressure rating of 80psi at a flow rating of 500 lbs/hr. pre injector. Then you have a RR set at 65psi post injector. Wouldn't the injectors be supplied with 80psi?
If so, why use a RR system? Or would it be best to install a pressure regulator pre injector to regulate the pressure to 65psi. or desired fuel pressure rating?
I'm not trying to stir up anything. Just curious.
Cory
'06, w/ Modded 62mm 03' turbo , 4in DP w/ 5in MBRP Exhaust, 58V FICM by Vivan @ Q.T., Sinister Delete, SCT Livewire (SRL tune from Matt @ G.H.), CTS Insight, Firestone Rear Air Bags
ptsk06tank is offline
post #2 of 36 Old 02-09-2012, 06:43 AM
Fox Hunt's Avatar
Quoted: 23 Post(s)
I have wondered this exact same thing. I hope someone chimes in.
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #3 of 36 Old 02-09-2012, 07:46 AM
pizza pig's Avatar
If you set the regulator at 65 psi the pump works to maintain that pressure, at 65 psi the a1000 is hardly any strain. The pumps max flow rating doesn't mean thats what its putting through the fuel rails/injectors the regulator decides that.
The idea of a regulated return is to supply fuel to the injectors and whatever fuel not use is sent back to the tank AFTER the injectors not before like the stock system or airdogs/fass. This provides the injectors with constant and equal fuel pressure in both rails and injectors.
pizza pig is offline
post #4 of 36 Old 02-09-2012, 08:01 AM
Fox Hunt's Avatar
Quoted: 23 Post(s)
Thats kinda what I thought, I'd never actually heard someone explain it though. trying not to get off topic, but does an injector getting 65psi work better/ make more power than one running at 50psi?
Sent from my HTC Hero S
Future Mods:
-Alex
Fox Hunt is offline
post #5 of 36 Old 02-09-2012, 08:12 AM Thread Starter
ptsk06tank's Avatar
OK that clears up things for me.
Also I'm assuming that a RR system will eliminate the "dead head" effect? Because having the back of the heads blocked off would put more strain on the fuel pump?
Cory
post #6 of 36 Old 02-09-2012, 08:16 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
Is an RFR system better than the Air Dog II or are they not really comparable?
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #7 of 36 Old 02-09-2012, 08:20 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
How about this. The RR maintains pressure up to 65psi THEN opens to allow fuel above 65 to by-pass to the return. So when under demand the RR would remain shut since the 80PSI would be feeding the injectors. One can assume the PSI at the RR will be lower than 65PSI so no fuel would be returned. (Kind of sounds like a dead head)
Once the fuel demand has dropped the RR should see a higher PSI (let's say it sees 80PSI). The RR opens to allow fuel pressurized over 65psi to return. This protects the potential of o-ring failure.
If you consider the OEM set up it does the same thing but the RR opens prior to feeding the injectors which should prevent the o-ring issue as well. As long as the OEM pump is providing adequate pressure it does the SAME thing as any RR setup.
I don't recall seeing where anyone has posted PSI output of the HFCM.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #8 of 36 Old 02-09-2012, 08:22 AM
pizza pig's Avatar
theyre not really comparable in my opinion
A regulated return is only good if your fuel pump is good!
post #9 of 36 Old 02-09-2012, 08:22 AM
N.S.D.Q.
Quoted: 97 Post(s)
RFR: does not filter or remove air. Just provides steady PSI
ADII: Filters fuel, removes air, provides steady PSI.
post #10 of 36 Old 02-09-2012, 10:28 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Thank you!
It seems that the RFR system would be a little cheaper, but the ADII makes more sense and a wiser investment. The RFR is simply masking the real problem which is the pump.
jimmyv13 is offline
