48V vs. 58V FICMs - Ford Powerstroke Diesel Forum
Old 01-19-2012, 07:24 AM
Turbos = Witchcraft
48V vs. 58V FICMs
I was reading through the Tuned FICMs thread and have been thinking that I want to get my FICM tuned in the future. I haven't checked the voltage on it yet, probably because it's 7 degrees outside and I am a wimp, but I was thinking that if the voltage is even a little bit low, I would get it repaired or replaced right away.
I just want to start a discussion on whether it is better to get a 48V tuned FICM or a 58V tuned FICM. I understand the concept of going to a higher voltage FICM, but I wonder if the extra heat generated by higher voltage will shorten the life of the FICM.
I'd like to hear your opinions.
Old 01-19-2012, 07:31 AM
I know I visited in depth with the guys at Swamps before I ordered my 58V with the PHP tune. They really cleared up alot of gray areas I had with the 58V units, especially in regards to towing since that's mostly what I use my truck for. Really great guys to deal with. As far as the FICM with the flash goes.... Turned my truck into a completely different animal! Night and day difference.
Old 01-19-2012, 08:05 AM
I'm in the same situation. Mine has dropped down to 40V on the -10 degree mornings a couple of times. Once I start it the voltage goes right up to 50V. Trying to decide weather it's worth getting the 58V or not. Quick Tricks website says once they have them in stock they are going to be about $400 with a lifetime warranty. People say it helps on cold starts which would help me out a lot here. Mine always starts good, but I don't want to let it go too long if the voltage is dropping on these cold mornings.
Old 01-19-2012, 05:36 PM
Turbos = Witchcraft
So we know that the 58V is safe for towing, and improves cold starting. Does anyone know if they last longer than the 48V or if it's about the same or less?
Old 01-19-2012, 05:45 PM
I Love Workin On Hotrods
Well all of the 58v units I've seen are upgraded with parts that are known to fail in the oem ones.
Old 01-28-2012, 12:53 PM
So is it worth spendind the $$$ to get a 58V and when you get a PHP, Innovative, KEM tune in the FICM can you also have a tuner installed (quadzilla, bullydog, sct, banks) and stack the tuner and FICM tune to make combined hp numbers?
