Good Injectors? - Ford Powerstroke Diesel Forum
Old 01-18-2012, 07:03 PM
Good Injectors?
I have an 04 f250 6.0, i finally have some money and want injectors next. I have arp head studs, black anyx gaskets, egr delete, and stock turbo. What injectors are best for a daily driver/heavy towing. I have a big 5th wheel, so i need to be able to haul that. I know that im gonna get casserly injectors, but what size?
Old 01-18-2012, 07:10 PM
back to business
What are your plans for air? Stock turbo, upgrade VGT, TWINS!!!!
Old 01-18-2012, 07:26 PM
155's. or 175cc if you wanna upgrade turbo(s) in the future,
Old 01-18-2012, 11:27 PM
Like others have said, 155's if your.not upgrading your turbo.. If you plan to do a pmax than maybe 175's.. But any bigger than that and you will need compound's to be able to hook on a decent load, without insane egt's
Sent from my SPH-D710 using AutoGuide App
Old 01-19-2012, 03:55 PM
What are good compounds to run? I dont need anything crazy, and with those compounds, what injectors?
Old 01-19-2012, 04:02 PM
190/100's with a 62/70 over s475
Old 01-19-2012, 04:11 PM
Would you go with powermax turbos?
Old 01-19-2012, 04:26 PM
if i get the innovative compounds, with injectors, is gonna make my truck run better? and will it make it last longer? i have 96k miles on it. I just wanna make sure because i dont wanna put all this money in it and make it blow up
Old 01-19-2012, 04:28 PM
This would be a VERY fun set up! I want to build one... my 62 over s480 setup spools great I would only imagine what a 62 s475 would be like.
Old 01-19-2012, 04:40 PM
build mine... when the time comes
