anyone running an ATS tranny - Ford Powerstroke Diesel Forum
Old 01-18-2012, 12:28 PM
Well I just bought a built transmission from ATS and it arrived yesterday. Well I called them up today to see if it took any special atf. Well the guy said it takes atf+4. All the research that I have done says atf+4 is for Chrysler vehicle.
Any ideas?
Old 01-18-2012, 01:24 PM
I Love Workin On Hotrods
Well I dont think ATS would lie to you about what their transmission takes but I would call again and explain it all and see what they say to be sure. JMO.
Old 01-18-2012, 01:39 PM
I would still use the Ford ATF
Old 01-18-2012, 02:12 PM
Ok that makes a lot of sense. Not. So he calls the manufacturer asking about what tranny fluid to use in his transmission and gets a recommended fluid and then for no other reason than it is a fluid usually found in chrysler transmissions, it is being recommended to use Ford ATF?? I'm sorry but I would need a little more info or something confirming the use of either fluid IMO. I recommend calling ATS and saying to whoever you talk to that you were recommended to use fluid X in their transmission that goes into a Ford vehicle but this fluid is usually found in chrysler vehicles and not Fords. Therefore, have them explain why that fluid is recommended over the Ford ATF and I am sure they will. I would be willing to bet (if it is infact what they recommend) it is because they probably use different clutches or something. Who knows but I would get more information. That's all I'm sayin. JMO. Take it for what it is worth.
Old 01-18-2012, 02:16 PM
back to business
Um, yep
Old 01-18-2012, 02:26 PM
Only reason I'm saying to use the Ford ATF is because it is a very good quality synthetic lube IMO.
Old 01-18-2012, 02:28 PM
you lost me at "i bought an ats trans" .. that was your first mistake...
However this wouldnt be the first time i've heard of people using different fluids in a built transmission. My brother's allison uses regular old trans fluid in his built trans where as the stock allison only likes transynd.
In a 5r110 though i'd only use Ford SP because the solenoids are picky on what fluid is used, and it needs to be clean. Im using SP in my trans
Old 01-18-2012, 02:33 PM
Which one?
Mercon? MerconIII? MerconV? Mercon LV? MerconSP?
ATF+4 is usually MercV in my experience.
Old 01-18-2012, 02:39 PM
Feedback Score: 3 reviews
The OP needs to call ATS and ask why. It may be because of the type of clutch material used.
When I went with Suncoast Superduty Kit, the instructions state "it is perfectly OK to use Dexron III or Mercon 5 fluid in this trans after the installation of this kit".
Old 01-18-2012, 02:40 PM
EXACTLY. That is what I'm sayin.
