Edge CTS questions - EAS add ons - Ford Powerstroke Diesel Forum
Old 01-16-2012, 07:58 AM
HMM HMM is offline
Forgive me I did search but didn't see it spelled out like I needed...
So I'm about to order me an Edge CTS. I understand needing the EGT add on. I'm guessing the EAS pressure sensor is so I can monitor fuel pressure. What can I monitor with the universal sensor input and do I need it?
Basically this is what I'm thinking of ordering so far:
(1) EDGE Insight CTS Data Monitor - monitor stuff that can be pulled via OBD2
(2) EDGE Insight EGT Probe Kit with EAS - monitor EGTs
(3) EDGE EAS Pressure Sensor - monitor fuel pressure
and this is the one I'm not sure I need:
(4) EDGE EAS Universal Sensor Input - do I need this to be able to plug the pressure sensor (#3 above) in without splicing wires???
Also do I need a fuel filter cap that is tapped so I can monitor fuel pressure or can I use that bung on the side?
Thanks!
Old 01-16-2012, 08:13 AM
From what I could find you have to have the universal input in order to hook the pressure sensor into the eas. Make sure you get the egt with the eas starter kit. Once you have the starter kit you need a universal input for every two sensors other than the egt. I would use the bung on the side of the filter cap and source a hose with the proper adapters from napa or a hose supplier. There was a thread with all the necessary fittings and part numbers somewhere... I think it cost them $9 or something.
Old 01-16-2012, 08:18 AM
you can visit Edge Insight Gauges for more info...
and yes number 4 is the kit you need for the fuel pressure sensor... you will also need the fuel bowl adapter that edge doesnt sell...
Old 01-16-2012, 08:29 AM
HMM HMM is offline
Thanks for the info. So basically I'm going to pay 129.00 so I can plug the other 129.00 part into it...typical...and then source the adapter.
Old 01-16-2012, 08:33 AM
lol yup... its about 300 bucks total...
if your interested in a whole package deal setup PM me and i can get you a price on everything you need
Old 01-18-2012, 04:28 AM
Short answer, yes. And yes it's pricey, but completely worth the piece of mind you get to be able to monitor your fuel pressure.
Components to read fuel pres: $300
New injectors cuz your fuel pres got to low and you didnt know it: $1500-$2000
2006 F250 Lariat FX4:
MBRP 4" Turbo Back Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle Mod
Dieselsite Coolant Filter
58v Swamps FICM
SCT w/ Matt's SRL Tune
6.4 Banjo Bolts
CCV Mod
Old 01-18-2012, 03:58 PM
HMM HMM is offline
Raul's got me hooked up with everything I need, all 4 of the above listed plus the adapter.
Thanks Raul!
Old 01-19-2012, 07:19 PM
i am doing the same can i also get a price thanks.. 06 f250
Old 01-20-2012, 02:40 PM
Arent you a busy man these days Raul
I think Edge has made a phenomenal product with this EAS kit now. Far simpler than mounting analogs. If only they could pull a few loose ends together and offer that fuel bowl adapter...
Old 01-21-2012, 06:11 AM
DieselManor - Accessories
You need the M12x1.5 adapter. Screw this into the fuel filter housing then screw Edge sensor right into the end of this adapter.
