custom diesel egr delete????? - Ford Powerstroke Diesel Forum
Old 01-14-2012, 09:09 PM
EGR Delete Kit | Ford EGR Delete Kits | Ford 6.0 EGR Delete Kit | Custom Diesel
Anyone run one of these kits looks like my cooler finally found a way to go to the scrap bin. Need to replace it and not a lot of cash.
Freakin truck seems to like my wallet bein light. Just had to do an IPR valve last week tie rod ends last month along with a complete brake overhaul. God im glad I can spin a wrench.
Old 01-14-2012, 10:24 PM
Once you pull it just weld in freeze plugs on each end save that cash for something else. Many other things to square up once your in that deep.
Old 01-14-2012, 11:23 PM
Kills me I was out running the truck a little hard trying to get the oil temp up to see if I could push the delta out of range for the eot ect. Oil cooler looks great. Popped the egr cooler I believe, going to check a little closer in the morning.
Aren't the coolers 304 stainless? I thought you had to tig 304 stainless. Am I wrong in this? Been known to be a few times more than I like to admit.
Old 01-15-2012, 05:05 AM
I don't know about the stainless thing but I know there are A LOT of people out there that just MIG weld the freeze plugs in there.
Old 01-15-2012, 08:48 AM
The custom diesel kit is almost exactly the same as the sinister kit but a whole lot cheaper. I have the sinister kit on my truck, but have installed 3 of the custom diesel kits. If I could do it over again I would use the custom diesel kit beacause of price. One of the custom kits was on a buddys truck who did the freeze plug thing. He replaced it with the custom diesel kit mostly for the up pipe. Says he noticed better spool up after.
Old 01-18-2012, 11:56 AM
Well come to find out it was just my hokey ccv mod. Good news truck is fine bad news I have no reason to buy and install an egr delete right now.
Old 01-18-2012, 01:18 PM
Old 01-18-2012, 01:23 PM
Yeah needless to say I feel like an idiot. The filter material I used to try to seperate the oil out of the off gas just completely loaded with oil blocking the pressure from exiting the crankcase there by pushing it through an oil seal somewhere.
Old 01-18-2012, 01:36 PM
Send a message via AIM to dieselmatt
At that price the EGR delete couldn't hurt to do unless you need it for emissions. As for the ccv...I just vented mine to air through a long hose to the back of the truck. Works just fine for me, no smell, and no mess on the driveway.
Old 01-18-2012, 01:40 PM
Its the down time on the truck that keeps me from doing it. Seems the only time I am off work is when its snowing or raining and I dont have a shop to work out of. maybe sometime this summer I'll have time and space to do it.
