Return to Stock??? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-14-2012, 11:18 AM Thread Starter
kafleming19's Avatar
Quoted: 781 Post(s)
Return to Stock???
I am going to be pulling my FICM today or tomorrow to send off to FICMrepair.com but I am wondering if I should return to my stock tune before doing so? I know they say they don't do anything with the flash on the FICM but I want to see what others do???
Kily AKA Lt. Axe
kafleming19 is offline
post #2 of 8 Old 01-14-2012, 11:26 AM
ars5147's Avatar
Quoted: 126 Post(s)
I didnt return to stock when I sent mine to Quicktricks. No problems at all when I got it back. You will be fine leaving what ever tune in.
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
2011 F150 SVT Raptor
ars5147 is offline
post #3 of 8 Old 01-14-2012, 01:17 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
While I havent pulled mine yet to be sent out, I definitely dont plan on returning the truck to stock when I do. FICM strategy is COMPLETELY independent of ECM strategy when it comes to changing either one.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 8 Old 01-14-2012, 02:21 PM
pizza pig's Avatar
you will be fine leave it as is
pizza pig is offline
post #5 of 8 Old 01-14-2012, 02:50 PM
back in the saddle
shu873's Avatar
I don't have a reason why, but I put my truck back to stock before I swapped my FICM for an Innovative mild tuned one. After the swap when I loaded up a tune again it didn't recognize my truck. Cost me an unlock on my Xcal. Not a big deal but I wasn't expecting it at the time.
The last truck I had was an 05 and I had a superchips tune loaded up on it. I got called in for a recall under warranty. I unloaded the tune first and put it back to stock. When I got the truck back they had reflashed it. Had to send the superchips tuner back in to the manufacturer to get it updated before it would work again. That was in the old days....
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #6 of 8 Old 01-14-2012, 05:58 PM Thread Starter
Quoted: 781 Post(s)
Thanks guys! Pulled it and going in the mail. Man those plugs are a PAIN!
Kily AKA Lt. Axe
post #7 of 8 Old 01-14-2012, 06:18 PM
BACKYARDIGAN
Quoted: 4 Post(s)
I bet they were. Just make sure to use some electrical grease on the connectors when you reinstall it as if you have to pull it again, the job should be easier then.
Nate
post #8 of 8 Old 01-16-2012, 02:49 AM
Why does my truck miss out if I return it to stock setting. Around 40 mph and more. It's like the turbo is missing ever so often. I have the SCT with no custom tunes. Help!!!
2004 F-250 Crew Cab 4x4
5" MBRP Turbo Back No Cat or Muffler
SCT X3 GearHead SRL
Edge Insight CTS
Glow shift 4 pod Gauges: Tranny, fuel pressure, EGTs, and Boost
Blue Spring Update
6.4 Banjo Bolts
Sinister Coolant Filter
AFE Stage II Cold Air Intake
More to come is
Studs, Oil Cooler, EGR delete, Coolant Filter, Air Dog, bigger injectors, and Water/Meth Injection
demott930 is offline
