Boost gauge not reading - Ford Powerstroke Diesel Forum
Old 01-14-2012, 10:07 AM
I just finished installing my autometer boost gauge and its reading 0 when i spool it up. Its an electronic gauge so all it has is wiring no tube. I put it in the intake elbow. Any suggestions?
Old 01-14-2012, 10:28 AM
I Love Workin On Hotrods
Check your wiring to make sure you did it according to the instructions and that your connections are solid. I know it needs a switched 12v source, a ground, and the sensor wire. Not to mention the wiring for the lights. I had an autometer temperature gauge once on my small block chevy that would just peg high all the time and it was because I had a bad ground. Hope this helps.
Old 01-14-2012, 11:23 AM
Thanks ill check all the wiring again but im pretty sure its all good. Could it be the sensor orcspmething? Seems pretty hard to screw up but i guess i did
Old 01-14-2012, 01:14 PM
It could be but autometer gauges are pretty high quality stuff. The likelyhood that you have a bad gauge is probably 10x less likely than you didnt wire something up properly. So there is a chance it is bad but I never really hear autometer guages not working.
Old 01-15-2012, 02:12 PM
Srove my truck today and the boost gauge is reading now. Yesterday i just power braked and it wasnt getting enough boost to register... Guess i am the dummy
