EGR delete & pesky CEL - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-13-2012, 09:25 PM Thread Starter
Has anyone figured out how to get rid of the pesky CEL after a EGR delete, besides a tuner. Like a calibrated leak on the EB pressure tube when the EGR is suppose to open...
drgrcr is offline
post #2 of 17 Old 01-14-2012, 05:42 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I'm gonna guess no on this one. What would be the purpose besides "not having to run a tuner"?? I wont say that it seems like a stupid idea but seriously, really? You would rather have exhaust leaking into your engine bay (I dont care how small of a leak it would be) than to just go buy a tuner to get rid of the CEL?? That just seems a little rediculous to me. JMO and am curious on the reasoning is all.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 17 Old 01-14-2012, 05:49 AM
Term3's Avatar
Quoted: 2 Post(s)
Check the forums for a used tuner to turn it off if that's all you want to do. Lot better then rigging up some hillbilly crap on your engine.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 17 Old 01-14-2012, 05:51 AM
BACKYARDIGAN
Quoted: 4 Post(s)
Amen
Nate
post #5 of 17 Old 01-14-2012, 07:39 AM Thread Starter
Oh.....if ya can't buy....it can't be done. That's what I get for being old school hot rod....silly me. Do you get a free T shirt with the tuner?
drgrcr is offline
post #6 of 17 Old 01-14-2012, 08:00 AM
Powerstroke Techie
justinmix's Avatar
No, there is no way to "trick" the PCM into thinking the EGR cooler is still installed. You can't really go messing with the EBP sensor because it's also used for turbo management. The only other way to not have to use a tuner on a 06 up truck is to get your PCM "backflashed" to an 05. PHP does stuff like this but it's still around $200 I think. I'd just go the tuner route.
justinmix is offline
post #7 of 17 Old 01-14-2012, 10:24 AM
fordfan30's Avatar
just plug in your egr valve and let it ride on top of the engine. No more light
06 F250 4x4 ecsb, lowered 2", 6 Autometer Phantom 2 guages, Accufab Elbow, Zoodad, Airaid , Magnaflow 4"dp, 5" pipe 7" short stack, Studs, Egr delete, sneaky pipe, regulated fuel return, 6.4 banjo bolts, Moderate FICM from Innovative, High idle and foglight mods, Bilsteins, Sulastic shackles, DIY Harley headlights and traction bars. 8.76 in the 1/8th
fordfan30 is offline
post #8 of 17 Old 01-14-2012, 10:38 AM
Powerstroke Techie
justinmix's Avatar
On a 06 up truck you will still eventually get a check engine light when the PCM detects no EGR flow. Plugging the valve in will keep the check engine light from coming on right away, but eventually it will throw the light on. Unless you know something I don't know.....
post #9 of 17 Old 01-14-2012, 01:06 PM
fordfan30's Avatar
mine has been riding on top for over 2 years
post #10 of 17 Old 01-14-2012, 01:08 PM Thread Starter
This is for a friends vehicle who doesn't understand why she has to put a egr cooler on her truck every 3 years, she doesn't care about performance as much as she does reliability. So I have offered to replace the cooler with a delete kit and told her about the side effect is the CEL. Looks like she will have to come up with another $200-300 dollars.
I did a EGR cooler delete on a 05 Excursion and left EGR valve connected to the wire harness and it does turn the light on after about 45 minutes of drive time, the owner of the Excursion doesn't care he was glad it was blowing steam anymore and he didn't blow a head gasket.
I have an idea that I am going to bounce of old calibrator friend and see what he thinks. If works it will be a lot more cost effective that a tuner. for people who just want reliability.
drgrcr is offline
