Turbo feed or drain line update?
I am doing an EGR delete on my 05 6.0 along with some other things while i'm in there and want to know more about the turbo drain and feed lines.
Which has the bend from the factory? the drain line? Should I just go ahead and replace both? |
both, the drain has crimps, and the feed line has a part that can internally collapse, heres the Part numbers from tousley ford....Feedline #-3C3Z-9T516-A Drain Tube#-6C3Z-9T515-A
wow tousely ford is much cheaper than other site sponsors. the markup is obvious now. glad I took a look before pulling the trigger. save $40 bux on the drain tube.
yeah 10-4 on that they are way cheaper on everything!
yup, the STC kit is like 37 where as most vendors want 65 for them
adds up to a lot if you're getting all those little things. Which I plan on doing, gonna pull the motor out of the truck and re-stud it so gonna update all gaskets, o rings, and oil tubes lol
