Different Tunes different Deltas (ECTvsEOT) - Ford Powerstroke Diesel Forum
Old 01-05-2012, 08:38 PM
I drive the same route to work every day. Its socal, so the weather is pretty constant, and there is usually no wind. I have noticed that I get different Deltas depending on which tune I run, with all other factors equal.
Not drawing any conclusions here, just my observations:
Stock: would run EOT 196-197 ECT 190 driving 65ish unloaded on my route (30 miles 1 way)
Extreme Street: runs EOT 198-200, ECT 190-192 same conditions
Looney: Runs EOT 197, ECT 190 same conditions
Seems to me that looney gets up to temp faster, and rises quicker when I get on it a little bit, but overall the EOT is slightly cooler than extreme street.
Old 01-05-2012, 09:15 PM
Mine run consistant about 0-3 degrees out on what ever tune I run from stock file to my race tune.
Old 01-06-2012, 02:32 AM
I really can't see that small of a difference as being anything more that normal variation.
Old 01-06-2012, 06:09 AM
I disagree - its noticeable. But then again Im completely fixated with looking at the stupid scangauge.....dang these trucks make us hypersensitive
Old 01-07-2012, 09:02 PM
I have a dumb question: what is a delta I hear it spoke about a lot....
Old 01-07-2012, 10:27 PM
When you see delta on here, it's usually referring to the difference in engine oil temp and engine coolant temp. (EOT & ECT)
Old 01-08-2012, 10:54 AM
Spartan I run a 2 degree delta and x race I run 4 degree delta
Old 01-08-2012, 11:05 AM
That's prett low, but you have egt delete..... Is the ect temp sensor downstream of the egt cooler? Does that make sense?...
Old 01-08-2012, 11:54 AM
I Love Workin On Hotrods
Well when you say "everything else equal", what do your EGTs average with each each tune?? I would submit to you that if you have a tune that runs a higher average EGT than say stock, which is usally the case with any performance tune; then you will have higher oil temps with that tune. (Kind of like towing) Either way I wouldnt be worried about it. JMO.
Old 01-08-2012, 01:09 PM
I don't have an egt probe, just equal in terms of speed, conditions, load, etc etc. I was mostly trying to compare looney to extreme street, for me it seems like eot stays lower with looney when just cruising.
