Egr delete and blue spring kit install - Ford Powerstroke Diesel Forum
Old 01-04-2012, 09:09 PM
Gonna install my mkm Egr delete and blue spring upgrade this weekend anyone got install instructions or tips ? Thanks guys
Old 01-04-2012, 09:34 PM
Winning DUHHH
My tip is to replace the oil cooler as well....Where ya located?
Old 01-04-2012, 10:12 PM
Did oil cooler delete 2 months ago when I did hgs and such put a new Egr cooler cause didn't have money for a delete and cooler was under warrenty
Old 01-04-2012, 10:13 PM
And Alberta Canada
Old 01-05-2012, 04:52 AM
Originally Posted by powersmoker1429 View Post
And Alberta Canada
yeeeehawww!
Old 01-05-2012, 05:07 AM
It's not bad at all. If you're going to take the upper coolant hose off while you're doing the delete that's the easiest way to get at the cover to install the fuel spring. As far as the EGR delete just loosten all your exhaust stuff up before you take it apart. This makes putting it back together a lot easier when you have to line the Y pipe back up. And take your dipstick out before you start climbing around under the hood or you're going to break it. I learned that the hard way.
Old 01-05-2012, 11:36 AM
Here you go this is a great post by Band_ Member on the fuel pressure reg spring install. Just remember about 99% of the 6.0 running around have low fuel pressure and don't know it.
Fuel Regulator Upgrade w/ Pictures - Diesel Forum - TheDieselStop.com
2 stroker
Old 01-05-2012, 12:40 PM
And get someone on top of the engine to hold the nuts on the up pipe, it will save a lot of time, and remove the downpipe if possible, it gives a lot of room to work. Good luck and don't get mad, it takes a good bit of time to do and being patient pays off, trust me.
