Anyway To Improve Lower End Torque?
I've had my truck for a little over a year now and done the studs and gaskets and all that and am running a SCT programmer with the SRL+ tune. This truck is quick but I have been very disappointed with the towing performance of it. I was thinking gearing may would make the biggest difference so I took off the 34" tires it had when buying and put on some 31.6" tires and it hasn't seemed to make any noticable difference. The power band just seems to be way up in the RPM range and not where I tend to run it unless I wanted to race or something.
I have heard that a FICM reprogram will help the lower end out, anyone had this done and is it worth it? Also I have straight 4" no Cat so by not having that backpressure could this be hurting my lower end torque? Any more ideas of improving the lower end torque? I had test drove a 5.4L gas F250 that felt torquier than my 6.0L. It's like a 2-stroke dirt bike as it's a dog till it's wound up and hits the power band then it's gone. Just not what I want from a Heavy Duty truck for towing.
Don't know if it would help but do you know your fuel pressure because about 99% of the 6.0 running around have low pressure and don't know it the only way to check is with a fuel pressure gauge. Pressure under 45lbs at WOT kills injectors mine at 17k had pressures of 44lbs WOT and 50lbs Idle installed the new reg kit now 58lbs WOT and 62-64lbs at idle may not be your problem but good to know what it is if you pull a 5er or TT because you are in WOT alot
![]() 2 stroker |
do you have a 4 inch downpipe?
I would consider re-gearing if you think you need more torque, especially if you tow. Step up to a set of 4.30's. Your hiway rev's will be higher but that's the trade off.
Sent from my Droid using AutoGuide.Com Free Last edited by PGreenSVT; 01-04-2012 at 07:28 PM. |
Try a different tow tune
I got the MBRP 4" system and it has the 3.5" down pipe.
Maybe I'm just not used to a diesel, I have never really drove one prior to this and I know there is turbo lag and all but it just doesn't seem to make any power till you get up around 2300 RPM, at that point on up the truck is a beast but that's not where I need the power 98% of the time. Looking to improve the torque band between 1500-2300 RPM. |
I've tried a few different tunes and none seem to make a difference on the low end, each one feels different on top end.
Shawn |
