Burning smell after pmax install. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-20-2011, 04:36 PM Thread Starter
Fox Hunt's Avatar
Quoted: 30 Post(s)
Just installed my powermax and took it out for some driving and I can get an oil burning smell in the cab. Only drove it for about 15 min. Stop at the house to pop the hood and i can see a light smoke coming from the back side. Shut the truck off and it was still there. So my question is its this just normal burning off the oil that was in the turbo/ housing getting hot for the first time or to you think I have an oil leak? Didnt see anything leaking but doesnt mean there isnt.
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #2 of 12 Old 12-20-2011, 04:42 PM
Quoted: 3 Post(s)
I think your fine, my 38r and my uppipes did the same thing.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 12 Old 12-20-2011, 05:07 PM Thread Starter
Fox Hunt's Avatar
Quoted: 30 Post(s)
Sweet. Thanks. I know my exhaust did the same thing when I installed it but it was gone after a quick drive
Sent from my HTC Hero S using AutoGuide App
Future Mods:
-Alex
Fox Hunt is offline
post #4 of 12 Old 12-20-2011, 05:24 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I would say that as long as it goes away with some driving and you dont see anything leaking that you would probably be ok.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 12 Old 12-20-2011, 10:46 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Changing the turbo had to get some oil on the engine and it is probably just burning off. If it doesn't go away then you have a problem.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 12 Old 12-21-2011, 06:28 AM
back in the saddle
shu873's Avatar
Ditto. Everytime I change a turbo there is always a little oil that leaks out of the housing in to the valley when I remove it. It burns off when you start the truck back up after you reinstall the turbo. It's normal but should go away within an hour or so.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #7 of 12 Old 12-21-2011, 06:31 AM
Quoted: 5 Post(s)
They coat the turbos and internal parts so they dont rust while sitting on the shelf. It will burn off and then its time to have fun.
a2elvis is offline
post #8 of 12 Old 12-22-2011, 04:36 AM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
Hey Fox Hunt, quick question for ya... did you notice any power increase with the Powermax? I see that you don't have sticks yet, so I know that you aren't unlocking the true potential of the turbo - but regardless, is your truck any quicker? Are you going to get new tunes now accomodating the bigger turbo?
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #9 of 12 Old 12-22-2011, 06:45 AM Thread Starter
Fox Hunt's Avatar
Quoted: 30 Post(s)
No more burning smell after a few days so all is good. Thanks guys
Future Mods:
-Alex
Fox Hunt is offline
post #10 of 12 Old 12-22-2011, 06:54 AM Thread Starter
Fox Hunt's Avatar
Quoted: 30 Post(s)
Ya I dont have sticks or studs so right now Im running Matts Powermax SRL. So far I love it. definitely more power. Havent done any 0-60 to compare yet but the butt dyno feels it. Can break the tires loose at around a 15mph roll- wouldnt do that before. I also added the batmowheel so I cant tell you what gains just it added but when I floor it there is just a half sec of lag and shes GONE. As as for egts cruising on flat ground its usually 740ish. Can see over 800 just going up over passes. I wish is was a bit lower but those arent terrible numbers. Going up one grade with the cruise control on at 70 I hit 1000* didnt like that when I take into count I can really hammer on it going up a similar hill and only hit 1100* I know it was flowing more air than the stocker. I would imagine if I ran the SRL+ that would cool it down some as the + version allow for more boost but I dont know if I wanna try is just on stock studs. I know some guys do it, but I dont know if they run it with a powermax. Maybe when I know I have the extra money to do studs I'll run it tosee how long she'll go. But up to this point I have no complaints with the pmax. May try a TSD tune and see what they have to offer. Havent tired Matts tow tune yet and the smoke on the SRL is even less than before. I may try and get a video up one day. Hope this helps
Future Mods:
-Alex
Fox Hunt is offline
