Suggestions for 300k miles 05 - Ford Powerstroke Diesel Forum
Old 12-18-2011, 04:51 PM
Recently picked up another Ford F250 Lariat 05 CCSB and the truck has 290k mile already on it. This week I'm going to be putting in a EGR delete, 6.4 Banjos, Blue fuel spring and STC fitting (sometimes is hard to start hot). What else does anyone recommend to this truck while i have this turbo out? The trans shifts fine and was recently rebuilt and I have to assume the studs and gaskets have been done since the hood has coolant stains haha. Truck runs at about 188-190* coolant temps and oil runs right under that by 10*. EGR currently is dry and the truck runs great besides some long start ups when hot. Exhaust was probably next on my list.
Old 12-18-2011, 04:58 PM
I Love Workin On Hotrods
If it is hard to start when hot, then I recommend updated stand pipes and dummy plugs. Of course this is provided that you are cranking for more than 5 seconds. JMO.
Old 12-18-2011, 06:13 PM
Oil should never be cooler than the coolant temps
Old 12-18-2011, 06:38 PM
Remove the intake manifold and clean it out. I soaked mine in purple power for 4 days and that did the job.
Old 12-19-2011, 12:51 PM
I'd look to see if you actually do have studs. I've looked at several trucks that have coolant stains and still have the "good ol" head bolts.
Old 12-19-2011, 04:18 PM
Mine stays below coolant temp till truck warms up then oil temp stays about 5 degrees warmer truck usually runs 190-194 ECT and 194-200 EOT
Old 12-19-2011, 04:26 PM
Yes oil will take longer to warm up than the coolant. Mine lags as well until warm but once everything is warmed up, my oil temp is higher than my coolant temp.
