head gasket opinion - Ford Powerstroke Diesel Forum
post #1 of 18 Old 12-16-2011, 07:09 PM Thread Starter
head gasket opinion
I'm doing arp head studs I'm planning to use new oem head gaskets because iv been hearing bad about the black onyx. Is this the right move. Opinions please
05 powerstroke
crewcab short bed
18" XD hoss wheels 35"xnitto terra grapplersSCT tuner with three custom tunes
Volant CAI
4" mrbp exhaust with 5" tip
EGR delete with block off plate
2.5 inch leveling kit in front, 4 inch blocks in rear
mooseman0 is offline
post #2 of 18 Old 12-16-2011, 07:11 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Use OEM gaskets
dhanna6powerstroke is offline
post #3 of 18 Old 12-16-2011, 07:45 PM
Snake's Avatar
Quoted: 47 Post(s)
Yes, you're making the right decision.
Snake is offline
post #4 of 18 Old 12-16-2011, 07:50 PM Thread Starter
Thanks guys.
05 powerstroke
crewcab short bed
Volant CAI
post #5 of 18 Old 12-17-2011, 07:50 AM
sbarbee54's Avatar
Both work, I think it all depends on how well you prep both sides, motor and make sure you heads are sent to a machine shop checked for flatness and cracks.
2005 F-250 CC SB FX4 Lariat 6.0
SCT Live Wire Tunes By Quick Tricks
MRBP 5" Straight Pipe
Banks Intake
GlowShift 4 Pillar/4 Mirror Pod
Kenwood DNX8120/Diamond Audio System
10" Sky Jacker Lift W/Procomp Rezies
Amp Steps/TopGun Customz Dual Fox Stear
Yukon 4:56's
Zoodad Mod/6.4 Banjo Bolts/Blue Spring Mod
PMF Trackbar/Draglink
20" Helo Maxx 8's W/ Toto MT 38X15.50R20's
sbarbee54 is offline
post #6 of 18 Old 12-23-2011, 05:04 PM
How much would it cost, roughly, to have studs, heads, and an egr delete kit installed?
Active_Klutch is offline
post #7 of 18 Old 12-23-2011, 05:38 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
~5k give or take
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #8 of 18 Old 12-23-2011, 05:44 PM
Originally Posted by windrunner408 View Post
~5k give or take
Would the price be about the same for just studs and heads? I just got my first truck and I don't want to risk them blowing.
post #9 of 18 Old 12-23-2011, 06:42 PM
Power2336's Avatar
May be lower for just the studs and gaskets but while it is all torn down you may as well take care of the EGR, new oil cooler, dummy plugs, STC fittings, O rings and things that are known for going wrong with these trucks. Otherwise unless your doing all this work yourself you will be paying for pretty much the labor X2 when you do the rest of the work later on. I just had blown head gaskets and had them put in ARP studs and OEM gaskets but even though my EGR and oil cooler we still working fine I had them do the works on it just to make sure that later I didnt have to re pay for all the labor.
RCD 4.5" lift with Airlift system, 4" MBRP turbo back minus KITTY & MUFFLER, AFE Stage II Pro Gaurd 7 intake, SCT X3 with Custom tunes, EDGE CTS for gagues with Pyro Probe, ARP studs, BPD Egr, Updated FORD oil cooler, Diesel Site Coolant Filter, AirDog II, 6.4 Banjo's, Upgraded BLUE fuel pressure spring, autometer in cab fuel pressure gaugs, Mag Hytec rear Diff cover, Full HID Xeon lights with HID Foggs, Recon LED tail and 3rd break lights all on 35X12.5R20's Toyo M/T's, XD Misfit rims.
Power2336 is offline
post #10 of 18 Old 12-23-2011, 06:58 PM
Trucksource Diesel just did mine , go with STOCK HG's as they, and most that have done this will reccommend
'05 F250SD > Ranch Hand HD Bumper w/skid plate & KC's, 2.5" Leveling Kit, Firestone Rear Bags, 305/17 Goodyear Wranglers, Hide-a-Ball Hitch, SCTx3 by Vivian , EGR Delete, 4" open exhaust , 6.4 Banjo Bolts , Fuel Reg. upgrade kit , cold air intake by me , '03 Turbo by HPTurbochargers,46 gal.aux.tank, ARP Studs / Factory Gaskets.
Rmorgan711 is offline
