pcm question
If i get a pcm from the junkyard with the same exact part# is it the same strategy and if so should my tuner still work on it?
Tuner should not be an issue as long as you have returned to stock or have custom tuning. You will need to get the VIN programmed into it, because on a CAN BUS system sometimes if VIN's in each individual module does not match they will not talk to each other.
how do i go about getting the vin put in it?
