will an egr plug throw a check engine light with edge juice with attitude
hey guys i got a buddy sellin a diesel tech1 egr plug only for really cheap was wondering if it will cure the 6.0 egr issues(my oem cooler seems to be fine) and also if my edge juice with attitued will clear the check engine light like an sct would! also wanting opionions on the egr plug thanks!
EGR plug is a waste of money. The EGR valve isn't the issue and removing it won't do any good. Only way to cure the EGR concern is to completely remove the cooler. As to the code, it will clear it and then immediately come back.
ok. what is the block you have on your truck?
What year is the truck?
its an 05. im thinken pick up this egr plug for cheap and get it in there then delete or replace the cooler as quick as the funds come.
Blocking the egr flow will help greatly. It will not cure but it will help greatly with how the engine runs. You will mostlikely get an egr code for flow.
Look at this link about the edge. edge juice with attitude, no display, truck runs bad |
The egr delete will throw a code I have the sinister eger delete on my 05 and it doesnt make the check engine light come on but it will throw a code that comes up on my insight and sct when I look at it.
I have a full EGR delete and just haven't had the signature changed. I had just a blockoff plate which is different than the plug you are talking about. The blockoff plate goes between the up pipe and EGR cooler to block exhaust gases from getting to the cooler. Just removing the EGR valve and installing that plug or tack welding it closed won't do any good because the exhaust gases still come through the cooler.
