SCT SF3 and EGR Code - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-19-2011, 09:46 AM Thread Starter
BenSmeding's Avatar
Will the SCT SF3 tuner with its canned tunes remove the EGR code that you get then you delete the egr's on the 2007's? Came across one for a super deal and want it for my work truck. Just a concern that came up. Thank you!
2005 F250 In slow mode.
BenSmeding is offline
post #2 of 14 Old 11-19-2011, 09:51 AM
If its that good of a deal just get it......just double check that its unlocked.
06 F350 Traded
alwil is offline
post #3 of 14 Old 11-19-2011, 09:58 AM Thread Starter
BenSmeding's Avatar
The only reason I want it for is to remove the egr code.. Egr is about to go bad
post #4 of 14 Old 11-19-2011, 10:51 AM
Sorry I didnt read your sig before.....your innovative tunes can be adjusted to turn off the egr.....how are you loading your tunes now?
06 F350 Traded
alwil is offline
post #5 of 14 Old 11-19-2011, 10:56 AM Thread Starter
BenSmeding's Avatar
Oh no its for a different truck that's not on my signature. its a 2007 6.0 and i want to delete the egr but i don't want it to throw a code. The truck is a work truck that doesn't need anything great. this guy I came across is ganna trade my stock front bumper for it. but i want to make sure it will remove the egr code if i do it.
post #6 of 14 Old 11-19-2011, 11:02 AM
I am not sure if that would be one of the options or not, you could always ask Eric for a stock no egr tune once you delete it.
06 F350 Traded
alwil is offline
post #7 of 14 Old 11-19-2011, 12:00 PM
PerformanceMachineMFG's Avatar
If its can tunes and part #3015 then it will have the option to turn off the EGR valve.
-Matt H
Performance Machine & MFG.
Manufacturers of High Quality EGR Delete Kits for 6.0L, 6.4L, & 6.7L Powerstroke Diesels
Toll-free: 877-408-3256
E-mail:
PerformanceMachineMFG is offline
post #8 of 14 Old 11-19-2011, 12:26 PM
What Matt said. SF3 has a bunch of setup options and one of them is EGR delete. Just make sure the unit is unlocked or unmarried. Easy to check, just goto SCT website and they will explain it. It took me 3 tries to find one unlocked. 150 bucks to unlock from SCT.
tartfun is offline
post #9 of 14 Old 11-19-2011, 02:30 PM
Good point if it's locked I would sell the bumper and put some money with it and buy a brand new one. Make the deal so you can put it on your truck before you buy. If it isn't locked he shouldn't have a problem with that as long as you agree to take it.
-Matt H
Sent from my DROID BIONIC using AutoGuide App
E-mail:
post #10 of 14 Old 11-19-2011, 04:58 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Here's what to look for when buying a used SCT.
What to look for when buying used SCT for 6.0
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
