Smokes now...
Is it normal for these engines to smoke a little bit on startup after having the head studs and other stuff done? Mine NEVER smoked at all, ever, before having the work done. Now it's a purplish haze on startup... I think it's probably ok, but it's new so I was curious. Thanks!
i've always experienced this after replacing anything high pressure oil related or when the heads come off. It will wear off im sure, but you never know. Seems like whoever is doing the work on your truck doesn't know what they're doing (from your recent posts)
I wish I'd never taken it to them... Apparently, I should've taken it to Burger King and had it worked on... At least you get it your way!
So, the smoke thing may go away? That helps my feelings a little bit- I was worried... Thank you sir! |
ahahahahahaha thats funny i like the burger king quote! just keep an eye on it if its not gone in a week let us know we will try to help
Thanks, a little humor helps me cope, lol. I'll keep an eye on the smoke for sure.
Classic! Hope it clears up. Nothing worse than half a$$ work at a full price.
Stock tune... for a couple more days anyway...
It should wear off. If not its probably injector stiction.
Tuned it will do that in cold weather |
I was going to say if it has been relatively cold where you are when you are i.e. less than 40*F when you start, then it is normal as I saw that with my truck in the winter months when i would first start it in the morning.
