egt going crazy on start up - Ford Powerstroke Diesel Forum
Old 11-15-2011, 05:09 AM
So I've noticed that when I start my truck up the egt has been peaking up at 2000 degrees. I don't understand how it could be correct, last night I noticed that my egt was at 1150 ish and when I flashed the brights it jumped up a hundred degrees- seems like an error to me but im looking for some input. Oh yeah my egt is hooked up to my cts insight-
Old 11-15-2011, 11:29 AM
I have the older Edge Insight with the EGT plugged into it also and never had a problem, i would call edge you have a problem with the unit.
2 stroker
Old 11-15-2011, 01:49 PM
I Love Workin On Hotrods
Yep it sounds like a problem with the unit. There is nothing on the motor that could cause actual egts to reach those numbers without a load on the motor.
Old 11-15-2011, 02:50 PM
well this sucks!!!
Old 11-15-2011, 03:43 PM
Check your EGT probe connections to make sure they are making good contact. Also, you can't shorten the wiring to the probe or it will give you incorrect readings.
Old 11-15-2011, 04:11 PM
Feedback Score: 3 reviews
You might want to also check your ground connections, I had a loose battery ground to the block and caused my analog gauge to bounce/flutter.
