Propane Injection? - Ford Powerstroke Diesel Forum
Old 11-11-2011, 05:01 PM
Propane Injection?
Alright, I have read multiple threads on Propane Injection and if it is good or bad. It seems that their is many mixed thoughts on it. If I have it set up for fuel economy it's good right? How is it set up differently between performance versus fuel economy? More propane more performance? I like having a powerful truck and want to make it even more powerful in the future (turbo, injectors, studs, etc.). The main reason I want to add propane is for MPG's but will very much appreciate the power increase. My question is if it is "set up for MPG's" but I still put the skinny pedal down sometimes; will it hurt my truck? Also, since I plan on eventually doing a bigger turbo and what not will having propane be bad? My dad owns a propane company and I have really easy access to propane so I really want to do it. But only if it doesn't hurt my truck. Also I do not have head studs and already have it tuned. Am I at my power limit already until I do studs?
Old 11-11-2011, 05:42 PM
I Love Workin On Hotrods
Wow where to start with this. How about just stay away from it and look at something else for more power and fuel economy like an exhaust, injectors, turbo, etc. It is way better to build these truck to run on diesel.
I tried the propane for your approach but never got it to work. Even if I did and lets say it did raise my fuel economy, the cost of the propane will offset any gains in mileage. NOS will increase your mileage and power output but is dang expensive to fill and is hard on the motor IMO.
Running propane will supposedly increase the efficiency of the combustion but so will just about anything thrown in with diesel but at what cost. Usually these things raise your EGTs and I never liked the idea of compressing a flamable gas before it is in the combustion chamber.
Bottom line if you want to add anything, I would suggest looking at water/meth but other than that dont waste your money and just stick to building your truck up and take what mileage you get. Hope this helps.
Old 11-11-2011, 08:12 PM
if you could get the propane for free i think it would be worth it for mpgs but i wouldnt do it for hp as im sure it would raise cylinder pressures and could pop hgs on stock bolts
