$5000..what to do!? - Ford Powerstroke Diesel Forum
Old 11-11-2011, 03:57 AM
$5000..what to do!?
So I am the proud new owner of a 2006 f250 powerstroke and have about $5000 to throw at it right away. I have been doing A LOT of reading on this site and have a pretty good idea of what exactly I want to do, but just want to get a few opinions from others on the forum. The first thing i already ordered was the edge insight cts with dashpod and eas egt probe. The truck already has a sinister coolant filter installed and came with an sct x3 tuner with 3 tunes from innovative diesel. I think next I will go with the 4" xp series turboback exhaust from mbrp. Next will be the egr delete. Blue spring upgrade. truck has the 6.4 banjo's. oil cooler replaced depending on the delta when i get my edge cts installed. arp headstuds and head gasket. get the ford gold coolant out of the truck. All of these mods are things I want to do, not necessarily in the order listed, but want to know if I'm missing anything. Thanks for any/all responses
Old 11-11-2011, 04:05 AM
here she is!
Old 11-11-2011, 04:07 AM
Unapologetically American
Feedback Score: 4 reviews
If you need an oil cooler, I highly suggest taking a look at the Bullet Proof solution. Remote oil cooler, and EGR cooler or delete . If you went that route, I'd save the money you'd spend on HG's. They don't just fail normally, coolant in the cylinders usually forced them to fail. Congrats on the new truck
You're doing custom tunes from IDP, right? Other than that, I think your list is looking pretty complete
Old 11-11-2011, 04:09 AM
I Love Workin On Hotrods
Yea if you are going to delete the egr and install head studs then I would recommend looking at rebuilding the oil cooler. I realize it has a coolant filter on it and since you bought this truck used, you are probably not going to sell it anytime soon. So with that being said I would recommend you look into the bullet proof oil cooler delete kit. Yes it is expensive but you would never have to worry about an oil cooler clogging again. You could remove and throw away your coolant filter, and you dont have drop the coin on the expensive ELC coolant because none of that stuff will matter since you wont have to worry about your oil cooler clogging.
As far as the headstuds go, just make sure to use oem gaskets and replace every oring on parts you disassemble, and make sure the heads are gone through by machine shop. I know if you were doing all the work your self you would be able to get everything i mentioned done for $5000 but I dont know if you can with taking it to someone. Hope this helps. If you want to know more about the oil cooler delete just let me know.
Old 11-11-2011, 04:11 AM
i was actually just looking at that kit. Sounds like it may be the way I go for the egr delete and oil cooler replacement!
Old 11-11-2011, 04:12 AM
Ah man you beat me to it. I still like doing the head studs if you can but yes the BPD kit would most definitely save you from having to do head studs due to an oil cooler rupture.
Old 11-11-2011, 04:19 AM
There are a couple threads here now where people have tackled the install themselves. Oldbuck has a current one goign right now
You mean EGR cooler rupture?
Old 11-11-2011, 04:26 AM
BPD install project
Old 11-11-2011, 04:28 AM
If i do the BPD egr delete and oil cooler delete, would the studs be worth messing with? I plan on keeping the truck for a long time, so I don't mind spending now to save later, but I'm trying to decide if they are worth doing.
Old 11-11-2011, 04:39 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
I would do ELC coolant no matter what. If you have 5 grand to spend, and want to go with for gold you can go ELC coolant for maybe $20 more.
I just did my truck for less than $100 including the thermostat.
It is the stuff international recommends and you get a 300k service life out of it. So never touch it again.
